Heated Inlet Manifold
10 replies to this topic
#1 Redbaron6969uk
Redbaron6969uk
  • 167 posts
Posted 08 September 2010 - 05:13 PM
May be a silly question but would still be interested to know the answer.
What is the benefit of using a heated inlet manifold?
I have seen lots over the the years not connected as is mine.
And how would i connect mine while it still has a heater take off valve?
#2 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 08 September 2010 - 05:48 PM
Always wondered this myself, be interesting to see what it does, never bothered with mine
#3 monster_mini
monster_mini
  • 981 posts
Posted 08 September 2010 - 06:31 PM
be warned, many people have different views on this:P some say about how you want cold air(cold air induction) and others say that its good to have it connected up because it helps with atomisation:)
expect a war soooooon:P
#4 yeti21586
yeti21586
    He's A Lumberjack And He's OK
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 08 September 2010 - 06:37 PM
also doing a search helps as this has been covered many times i the past year
YetI
a quick search found this
http://www.theminifo... Inlet Manifold
#5 PhilipGCaldwell
PhilipGCaldwell
  • 870 posts
Posted 08 September 2010 - 06:59 PM
the search function is often as useless as a chocolate dick
#6 yeti21586
yeti21586
  • 3,738 posts
  • Name: Chris
  • Local Club: None
Posted 08 September 2010 - 07:01 PM
it just takes some getting used to
need to go to advanced options and change the search prefrences
#7 project mini chris
project mini chris
    have a break, have a...
  • 1,894 posts
Posted 08 September 2010 - 08:37 PM
It allows you to fit a large bore zorst system instead of cutting a std manifold apart. It also has a bypass along the top to run water through (as its name suggests). You can use it without using the water bypass bit.
#8 Redbaron6969uk
Redbaron6969uk
  • 167 posts
Posted 08 September 2010 - 10:45 PM
I would just like to say thanks everyone for answering my question...............................But I can't you have left me with more questions than answers lol. Makes good reading though so keep em coming >_<
#9 tadleysimon
tadleysimon
  • 1,458 posts
  • Local Club: basingstoke mini club
Posted 08 September 2010 - 11:14 PM
dont bother with it unless you have problems with carb icing
#10 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 09 September 2010 - 10:19 AM
Yes it helps warm the charge. You could also argue it keeps the temp of the manifold down but due to the size of the mini manifold and its relative volume flowing water through it is next to useless unlike more modern cars that have huge inlet manifolds that take some heating.
#11 atspeed racing
atspeed racing
  • 26 posts
Posted 09 September 2010 - 11:42 AM
If you have no "hot spot" on the inlet manifold like the cast iron manifolds have, then you need to heat the manifold up to stop it icing up.
Although this isnt a problem on a Mini, normally, but if you had the correct conditions this could be a problem.
I have had this problem before on a car and it was a **** to find.
