Cheap Electronic Water Pumps
9 replies to this topic
#1 samsfern
samsfern
  • 5,243 posts
Posted 08 September 2010 - 08:39 PM
as above, anyone know of any cheap electric water pumps?
im wanting to go for a leccy water pump, to take drag off the engine, and so when i switch it off after coming off track, it keeps water circulating, through the rad, electric fan of course, thus cooling the engine, rather than the temperature going up to over 110 celcius, normally goes to 120, when i switch it off after a session, due to no water circulation. it normally sits at about 95 on track.
#2 Big_Adam
Big_Adam
  • 7,435 posts
Posted 08 September 2010 - 09:35 PM
FleBay, I always thought a lotus one might work.
#3 samsfern
samsfern
  • 5,243 posts
Posted 08 September 2010 - 09:41 PM
cool, thanks
#4 samsfern
samsfern
  • 5,243 posts
Posted 08 September 2010 - 09:46 PM
any idea what sort of flow rate i should be looking for? thanks
#5 HARBER07
HARBER07
  • 4,498 posts
  • Local Club: Naaa......
Posted 08 September 2010 - 09:49 PM
Some flow would be the best rate to get >_<
#6 samsfern
samsfern
  • 5,243 posts
Posted 08 September 2010 - 09:50 PM
lol, yes would help, i was just worried of getting one that flows too quick, thus cooling it too much, ive found one on demon tweeks that should do the job, ill try and order it through work tomoz.
#7 SolarB
SolarB
  • 1,406 posts
Posted 09 September 2010 - 07:21 AM
Shouldn't the thermostat take care of that?
#8 Mr Joshua
Mr Joshua
  • 378 posts
  • Local Club: Rebels mini club
Posted 09 September 2010 - 10:11 AM
Buy cheap buy twice and throw in a cylinder head rebuild why your at it.
Next you will be asking for Cheap head gaskets. >_<
#9 samsfern
samsfern
  • 5,243 posts
Posted 09 September 2010 - 10:26 AM
i just cant justify patying nearly 200 from kad, lol
#10 Sprocket
Sprocket
    Great on Injection faults
  • 7,266 posts
Posted 09 September 2010 - 06:29 PM
Keep the mechnical pump and fit a small electric shunt pump for heat soak when you shut the engine off
