Hi, after doing my own service i seem to have this lack of power feeling, when i start to accelerate the car feels like i need to pull out the choke, but then seems okay again until i slow down then accelerate again?? the old oil was rough, was wondering if its because the new oil is filtering through? it didnt do it before the service. i didnt get round to the new spark plugs as i couldnt undo the old ones? could it be this? what have i done wrong??
whats up??
smalbutsweet
, Jul 11 2005 01:33 PM
6 replies to this topic
Posted 11 July 2005 - 01:33 PM
Posted 11 July 2005 - 01:38 PM
Sounds like it needs a little tune, but would be an idea to change the plugs, and maybe check the points/gap, also ideally the plug leads should be changed routinely
Posted 11 July 2005 - 09:11 PM
What did you do in the 'service' - it's nothing to do with the oil - what else did you do ?
Posted 11 July 2005 - 09:12 PM
if it sounds like it needs choke then it probaly needs more air. did u put a new air filter on it?
Posted 11 July 2005 - 09:33 PM
other way round mate. if it needs choke, then its running to weak, ie it has too much air.if it sounds like it needs choke then it probaly needs more air. did u put a new air filter on it?
Posted 11 July 2005 - 09:38 PM
yea thats the one!
Posted 13 July 2005 - 11:07 AM
I did put a new air filter in, didnt realise that you could just take the lid off, i took the complete housing off, was abit of a bugger to put back on, didnt want to sit over this silver foil thingy?? i took car out yesterday i ran on the choke for a good 5 mins then slowly put choke back in, seemed ok, so maybe i shouldnt be in such a hurry to run without the choke..
