hola. just rebuilt kaqtie's engine. it's a 1275, A-plus, based engine, with a Swiftune sw5 cam, basically, running on a HIF44, and electronic ignition, just got her started, and she is running really rich, and sounds like a traaaactor (by rich i mean, the sparky plugs were black with soot after 10 mins running). any suggestions of carb needles would be much appreciated, currently she is running on a BDL. or any tuning/fettling suggestions would be great, cheers all.
needle suggestions
clubman katie B.F
, Jul 11 2005 09:20 PM
4 replies to this topic
Posted 11 July 2005 - 09:20 PM
Posted 12 July 2005 - 08:20 AM
anyone?
Posted 12 July 2005 - 08:32 AM
As a starting point the BDL is a decent enough needle, and for it to be running rich with that on means your jet is way too low....
Try weakening the mixture until it starts to hunt ( labour ) then richen until idles comfortably ( should only be about 1/2 turn max )
If when you now open the throttle and it bogs down, it may be an idea to check the timing and then using a colour-tune to get the mixture closer at idle.
Needle selection itself is very specific to the engine and setup. It can be done on your drive, but a few quid spent on a rolling road session would be money sell spent.
Posted 12 July 2005 - 11:08 AM
cheers guessworks.....you are a star. seems to be getting a bit better. when we dropped the gearbox on to the engine, we had the engine upsideown so we think maybe some old oil got somwehre is shouldn't have
Posted 12 July 2005 - 12:17 PM
Don't worry about Colourtune - just test the idle mixture by lifting the carb piston. If it speeds up - too rich, if it stalls - too weak. But this is only the idle mixture - you need to do a good hard power run up a long steep hill - then switch off, coast to a halt - whip out the plugs and see the colour. White is too weak, black is too rich - you want light brown. Based on this you can decide is a different needle is required. A RR sesssion will help - but they ain't cheap !
