So here are the pictures of my supercharger bits. I'm not totally happy with them as they havn't been made to a high standard, and with them costing £250 each, I would kind of like them to be.
Inlet ManifoldThe inlet manifold has rushed and uneven weld, and they haven't attempted to finish or clean it up to look good.
As you can see in this picture, the weld is all rough and not properly finished off, and it is the same on the other side of the hole.
In this picture, the tube all the way around is rough and uneven and has metal filings in, which I know can be washed out.
And in this picture, a few rused welds have been put in and I'm not happy that they havn't really been tidied up.
Carb PipeThe carb pipe is better and the only problem I have with this is the rused weld on the little bracket.
In this picture you can see the rushed and untidy weld which I'm not happy about, but this is a lot better than the inlet manifold.
I know some of you won't be able to see what I'm moaning out, but I like things to look and be perfect, and at £250 a piece I shouldn't be expecting any less.
Edited by 1987_ParkLane, 13 February 2009 - 11:59 PM.
