Wiring Connector Plug For Removeable/flip Front.
Posted 15 October 2008 - 02:46 PM
I don't know where to start, any recommendations?
7 wires in and 12 out.
Russ
Posted 15 October 2008 - 03:21 PM
I need a good quality connector plug to separate the wiring for the headlights and indicators for a removeable fibreglass front.
Russ
The mate n lock connectors go up to 15 way:
http://www.vehicle-w...iconnectors.php
Others I have heard of using towing accessory wiring connectors, the kind of thing you connect up a trailer or caravan with...
EDIT: Don't forget the earths!
Edited by Jupitus, 15 October 2008 - 03:21 PM.
Posted 15 October 2008 - 03:29 PM
Posted 15 October 2008 - 03:49 PM
Posted 15 October 2008 - 03:50 PM
Just done an Ebay search for Trailer Plugs and they're looking favourite so far.
Those connectors look good David but may be a bit small for my sausage fingers. I should be buying the front end next week!
Posted 15 October 2008 - 03:53 PM
What's the score with an earth? What do I need to wire up to what?
Posted 15 October 2008 - 03:59 PM
Cheers guys,
my hourly rate isn't too bad , and the connectors aren't big and bulky and can be tucked away for a neat engine bay
Posted 15 October 2008 - 04:05 PM
Posted 15 October 2008 - 07:29 PM
I'm now thinking of using a standard 7 pin N-type trailer plug and socket but this won't give me a pin for an earth.
I'm thinking, run a wire from each indicator and headlamp to metal washers that will be tight against the subframe when the front is fitted.
Does this sound right or is it simpler than that?
Posted 15 October 2008 - 07:45 PM
Posted 15 October 2008 - 08:16 PM
The wiring will NEED proper earthing. That means tight firm clean connections to the body of the car.
Okay, I'll work something out then.
Thanks again.
Russ
Posted 15 October 2008 - 08:31 PM
Posted 15 October 2008 - 08:57 PM
Posted 15 October 2008 - 09:37 PM
and i would seriously consider small plugs to keep things neat
