Pistons Hitting Head Gasket?
Posted 16 October 2008 - 05:29 PM
Any ideas why?
Any posible fixes?
Posted 16 October 2008 - 05:38 PM
It's all down to the offset of the bores, the crown to deck height and the 'overlap' of the gasket into the bore...
I'll go find it.......
here ya go...
http://www.minispare...x?ty=ad&aid=576
Edited by GuessWorks.co.uk, 16 October 2008 - 05:39 PM.
Posted 16 October 2008 - 05:52 PM
if its the black BK450 then the AF 460 is worth a go, as i have it on good authority that the fire rings are a bigger diameter.
also cometic (sp) list 2 different gaskets for the 1275 A series one for the mini and one for the midget, the midgit one is listed as being for 74mm (rather than 73.5 for the mini one) and has a different thickness.
Posted 16 October 2008 - 07:44 PM
Posted 16 October 2008 - 09:27 PM
and guesseworks cheers for the link, just had a quick read of it and now severly *Drunk or yellow human water* off, looks like im going to need to take the engine back out and strip it to get the piston machined, Great!
Edited by insamoufonyx, 16 October 2008 - 09:40 PM.
Posted 16 October 2008 - 10:16 PM
Posted 16 October 2008 - 10:23 PM
I would pop the pistons out and machine them down in the lathe so they don't touch plus a small clearance. A chamfer is better than a step as any sharp corners can lead to cracks. Not a difficult job, just a PITA to have to pull the engine down!
Posted 16 October 2008 - 10:39 PM
Posted 17 October 2008 - 06:56 AM
Have you calculated you compression ratio? It must be quite high unless you have a head with big chambers.
Posted 17 October 2008 - 03:48 PM
Posted 17 October 2008 - 04:11 PM
Posted 17 October 2008 - 04:46 PM
Posted 18 October 2008 - 12:25 AM
Just a quick update, i know quite well Ian Slark (thouse of you into mini motor sport may reconise the name) he owns a resto place near me, hes the brother of Neil Slark (also in the racing scene) whos the owner of Slark Race Engineering - which as many of you will know they are pretty much the dogs bolloks lol. Neil is having a look at the head gasket and compairing it with some hes got lying around to check all is ok with that, if not theres the posiblity of having a custom head gasket made to suit.
