has any changed there front hubs, from drum brakes to callipers???????
i picked up a set of hubs complete with callipers from the scrappy yesterday, need to cleen them up and spray them so they are ready to fit, but what i want to know in can i use my old drive shafts, or do i need to change just teh knuckle joint at the end of the drive shaft????????
disc hubs and drive shafts
cowboy
, Mar 04 2004 09:27 PM
3 replies to this topic
Posted 04 March 2004 - 09:27 PM
Posted 04 March 2004 - 09:39 PM
ive done drums to 7.5's... best and safest thing to do is use all of the new parts u got... as i think the older driveshafts are shorter and i think the splines are slighty different too.
Posted 04 March 2004 - 09:49 PM
i think i'll remove drive shafts this weekend and see what the differnce is, will let you all know, unless someone tells me before then..... :grin:
Posted 18 March 2004 - 07:19 PM
managed to get drive shaft off both hubs today and No you can't just change them over, i will have to get the pot which goes into the gearbox aswell if i am going to fit them, decided to order 2 new drive flanges for now, will work on changing them over at a later date..
problem solved
problem solved
