well im getting my modified r1 loom back shortly and as im running the carb setup r1, the yamaha loom will run the engine side of things in addition to yamahas fuel pump,starter motor, ignition coil packs etc
the questions are this:
1. what do i do with the original mini alternator wiring in the engine bay?
2. apart from the ingnition key switch feeds , a batt positive and a ground what other connections are needed to mate the yamahas loom with the minis loom
does anyone have a basic wiring drawing or similar?
thanks!
Basic Wiring Info Needed
YIANO
, Dec 08 2008 07:58 AM
No replies to this topic
