Does anyone have any input on solid rockers and weather they make any difference to an engines performance?
solid rockers
moke
, Mar 05 2004 10:10 PM
6 replies to this topic
Posted 05 March 2004 - 10:10 PM
Posted 05 March 2004 - 11:06 PM
anyone?
Posted 05 March 2004 - 11:58 PM
The only difference rockers will make, is if you change the ration, on a 998 1.3 rockers are good, on a 1275 1.5 are good, and on big extreme engines 1.7... If your thinking of investing in some, go for the roller tip type, they make sooooo much difference to the power!! Its like adding a Kent 276 cam.
Posted 13 March 2004 - 06:57 PM
How much power we talkin? Roller rockers are expensive and i want a cheap, but fast car so only want to buy them if they'll be worth it!
Posted 13 March 2004 - 09:43 PM
Very very worth it!!! They they are instand bolt on preformance and you defo get your moneys worth from them. Also, they reduce side load on the valves which reduces wear to the guide and stem, thus waisting less energy in the whole engine cycle...
Posted 14 March 2004 - 02:14 PM
Sounds good, is there any advantage of full roller rockers over roller tipped rockers??
Posted 14 March 2004 - 05:58 PM
Not for a road car, full rolers have roller bearings on the rocker were the shaft goes thru it, where as roller tips have a bush, and it's unlikely on a road goin car that the bush is gonna wear out!
