Wheel Bearing
Posted 30 July 2005 - 11:49 PM
I had seen a few different bearings for sale at shows and i wasn't sure which one i need to buy.
So, i need to know what is the correct bearing i need to buy to replace the old one. The car is a 1990 racing green.
Any help is appreciated.
Mike
Posted 31 July 2005 - 08:08 AM
That said it's probably worth getting one from a reputed trader if buying from a show. I got one from Minimine.
You can buy Timken type bearings which are of better load bearing design and will last longer, however on a road car I'm not sure if it is worth paying the extra for these.
Posted 31 July 2005 - 08:28 AM
Posted 31 July 2005 - 10:52 PM
yeah i agree miniman5this noise, could be the CV joint
RacingGreen what noise does it make?
brett
Posted 31 July 2005 - 11:00 PM
Is everyone listening carefully?
Good.
Timken wheel bearings are standard on all disk braked Mini's except the original Mini Cooper.
Ball bearings were used before that.
You must use Timken type taper roller wheel bearings.
If the noise is continuous it's most likely the wheel bearing. CV joints only knock when turning corners in most cases.
Posted 31 July 2005 - 11:14 PM
Does this sound about right for it being a bearing?
Mike
Posted 31 July 2005 - 11:28 PM
Posted 31 July 2005 - 11:48 PM
Mike
Posted 01 August 2005 - 06:45 AM
Any suggestions anyone
Posted 08 August 2005 - 11:15 AM
Thnaks
Posted 08 August 2005 - 11:53 AM
Posted 08 August 2005 - 03:32 PM
Posted 08 August 2005 - 07:13 PM
Posted 09 August 2005 - 03:55 AM
As for the noise. the only suggestion I can give is get the car up on axle stands (front wheels off the groud), run the engine in first and listen.. first with wheels full left lock, and right lock then straight ahead..
