Hi all, i may have to get a replacement 998 A+ engine and, wonder if any one knows of places in Plymouth or surrounds where i can try for one in reasonable condition, many thanks.
Sean
engine
mayfairman
, Aug 05 2005 04:00 PM
10 replies to this topic
Posted 05 August 2005 - 04:00 PM
Posted 06 August 2005 - 10:28 AM
ebay?
Posted 08 August 2005 - 08:17 AM
Anew engine is now not required as Outcast came over and had a look and said the timing belt was probably the cause of the noise, as the AAman said it sounded like the camshaft.
We took the cover off and found that the tensioner had sheared, problem solved.
Am now getting a complete new timing chain and seals as engine has just under 100,000 miles on the clock.
Thanks Outcast.
Thanks Outcast.
Posted 08 August 2005 - 08:20 AM
struth! that was going to cost you if you didnt find that that was causing the problem!
Posted 08 August 2005 - 08:25 AM
If you hear a funny ticking noise that could be the cause.
Lucky it did not get caught in the chain and trash the engine,so now we can put the money towards getting some new panels for her mini, it certainly saved a few quid.
:grin: :grin:
:grin: :grin:
Posted 11 August 2005 - 08:29 PM
After having replaced timing gear,tensioner and the rest it is still making the same noise like a ticking tappet type noise help
Many thanks Sean
Posted 12 August 2005 - 08:45 AM
after replacing the timing chain and fittings will it take a long time for the oil to work it's way arond the chain and would this make it noisey like a tappety noise until then.
Sean
Sean
Posted 19 August 2005 - 08:08 PM
After replacing the cam followers done by Bluemini many thanks at a bit of a mare of a job.However the noise is still there so he suggested replacing the petrol pump,but we were thinking that if that doesn't solve it we will have to replace the engine.So we have had the possible offer of 998 metro engine,will we have to make any major changes to the car or will it fit straight in with out any conversion.
Many thanks Sean.
Many thanks Sean.
Posted 19 August 2005 - 10:14 PM
Have you tried the guy out at ivybridge? He has a few engines sat around i think.
My old 998 did the same thing snapped the chain tensioner, before realising this was the problem i put on a new alternator and water pump thinking it may have been these bearings.
And the metro engine pretty much all is the same possibly the ignition will be different but there are wiring diagrams on the forum, and a transferal of mounts but thats about all i had to do when i put a metro 1275 in mine.
Posted 20 August 2005 - 08:21 AM
Its no big deal swapping engines and fitting a metro one instead.
Check that fuel pump first tho.
Posted 25 August 2005 - 01:41 PM
Have replaced the engine and the noise has ceased she is running fine we are now able to go on the N.D.G.T this weekend.I am now going to strip down the old engine and see if i can find the problem many thanks to every one, will let you know if i find what the noise was.
Sean
Sean
