just had a day of nightmares! the stereo doesn't what to work. i did as you said, or at least i think i did.
the stereo (aiwa model ct-x320yz)has got the following wires which are labelled:
red- power (acc)
yellow- to battery (back up) fuse 15a
black - gnd (negative ground)
blue - relay control to power antenna
brown - car telephone mute
i have connected the red wire to the ingnition switch at the same point as the white and red wire on thyen ignition switch.
i connected the yellow to the starter selonoid. (the car mayfair '83 has a remotely mounted stater solenoid). i connectected it to the cable that comes from the battery.
i connected the black to the same earth point as the wiper motor.
the speakers where straight forward.
i dont know where i went wrong can you help please.
fitting a stereo 2
tam0123
, Aug 08 2005 02:19 PM
1 reply to this topic
