ok can someone sort this for me.....
i think my alarm is up the swanny(built in 93 cooper 1.3i)
the beast won't start on the key i have to either bump it or a screwdiver across the solenoid.... :saywhat:
i had probs wiv the battery and alternator which are now sorted, but, the alarm still wont work.....
i get all ignition lights but it just don't turn over on the key.
measured volts at solenoid while mate turned key wich was 8.5-9v
if its the immobiliser can i disable it if so where is it and how? :sick:
cheers folks
immobiliser
simmo
, Mar 08 2004 07:12 PM
12 replies to this topic
Posted 08 March 2004 - 07:12 PM
Posted 08 March 2004 - 08:34 PM
that doesnt sound too good, :erm: has someone boken into it and tried forcing it to start without the key? because that may put the immobiliser into action causing it not to start.
Posted 08 March 2004 - 10:45 PM
s'pose that could av happened .
was working when i put it in the works compound
then next day didnee
any fixes?
any fixes?
Posted 09 March 2004 - 06:46 AM
was it a factory option? or aftermarket fit?
because if it were a factory fit maybe you could go to a local Rover dealer and theyll sort it out.
Posted 09 March 2004 - 07:17 AM
factory fit,.. i'll give rover a ring from work..
cheers
cheers
Posted 09 March 2004 - 01:58 PM
well i called rover, lot of good that was
don't think they have got a clue, they wanted to charge me
70 sovs... or a new fob @ 50 saovs all plus vat
so solution is hot wire to solenoid starter button and a key switch
i've got laying around :smartass:
unless you lot have any other ideas :grin:
Posted 09 March 2004 - 02:21 PM
hmm thats a bit ott from rover. well yea maybe. unless u can find another specilist in security who specialise in minis?
Posted 09 March 2004 - 10:23 PM
does the engine turn over when yoiu try to start it?? cause 8.5-9v at the solenoid sometime's isn't enough to turn engine over, and if you can start it by bumping or across solenoid then immobiliser not working as it should!!!!!!
Posted 09 March 2004 - 11:24 PM
The immobiliser should cut all power to the starter solenoid. As its a 1.3 i I guess this engine has the pre-engaged starter with the solenoid on top. If its onlt 8 to 9 volts when it should be 12 then it could be the battery.
Check the battery again to start with there may be a live that is draining the battery if its left standing, if its not that then it could be a knackered starter motor.
The key fob the alarm, does this active and disable the alarm, is there a blinky flashy led anywhere doing a blinky flashy thing at you. I f so battery is knackered in the key fob, just replace this and see what happens.
Above is only a guess, with a mini check EVERYTHING!!!!! :grin:
Posted 11 March 2004 - 12:22 AM
will try battery in keyfob...though it flashes when i press the button :erm:
the led in the car doesn't light up... normally the indicators flash and the led in the car blinks on
cheers
cheers
Posted 11 March 2004 - 02:33 PM
hmm perhaps a faulty sensor
Posted 11 March 2004 - 11:53 PM
where would that be? :erm:
Posted 12 March 2004 - 09:42 AM
err i dunno umm i thought other people might know. hmm, how does ur immobiliser activate?
