Do an FAQ/or have pictures for fitment of a curley carbon dash, as im in the market for one around november time, and i have not a clue how they fit. Are they pop riveted to the front windscreen 'rail'? Also what have people done with their steering columns, do you need a UJ?
is anyone able to...
Madmax
, Aug 08 2005 11:28 PM
6 replies to this topic
Posted 08 August 2005 - 11:28 PM
Posted 09 August 2005 - 03:26 AM
You mean to say you spend a vast quantity on a curley dash and it does not come with fitting instructions.... hmmm... makes you wonder...
Posted 09 August 2005 - 08:24 AM
I dint know about the fitting, but I would guess you would use a "column drop" to lower the wheel. Its a steel bracket, normally costs about 4 quid.
Posted 09 August 2005 - 01:40 PM
lol guessworks, i meant tips/hints, im sure theyre not as straightforward as they seem...
that drop brackets the same as i have at the moment mat, i was more thinking of how to extend the gear inkage, possibly with a universal joint.
Posted 09 August 2005 - 02:48 PM
It is a bit of a pain re-locating you choke cable. you also need a longer choke cable than standard as the only place strong enough for it is on the centre console. This still flexes the hole dash when you use it.
I have got 4 screws in total to locate the dash in position. the dash itself sits on the top dash rail. A screw at either end holds it flush with the bottom dash rail. There is also a screw either side of the centre console that fit it to the exhaust tunnel. Then when I fit my roll cage it is flush with the bottm dash rail and therfore traps the dash between it and the dash rail which fixes the dash reallly securely.
I extended Heater lever usings some stiff metal wire.
Posted 09 August 2005 - 02:54 PM
another pic
