Whats the best way to insulate the float chamber? I can't restart my car when its warm without allowing the float chamber to cool in some way. Is exhaust wrap the only thing i can do? Does anyone else get this problem?
Cheers Jimbo
Boiling fuel
jimbo_edmondo
, Aug 09 2005 06:44 PM
10 replies to this topic
Posted 09 August 2005 - 06:44 PM
Posted 09 August 2005 - 06:47 PM
Do you still have the (useless) steel heatshield?
Dads MG has the same problem, with twin HS4s. His (asbestos) heatshield has gone, but my old MG was fine as it had some of it still remaining.
Posted 09 August 2005 - 06:48 PM
Heat sheild?...
Posted 09 August 2005 - 06:50 PM
Between the carb and the manifold there should be a steel plate. Some carbs have a return spring attatched to it. This is the heatshield for the float bowl. Is it there?
Posted 09 August 2005 - 07:01 PM
Nope don't think its ever had one. So that'd be a good way to go then lol! Its got a Hiff 44 on it will one still fit with that?
Posted 09 August 2005 - 07:11 PM
I would guess so, but I only play with HS4s. Get a piece of steel sheet 91mm is plenty) and cut a shape that is useable. You would need to drill/ mill a hole in it the same size or bigger than the carb inlet. A HIF 44 is 1.1/2 inch I think. You need to get that lined up with the inlet THEN drill holes for the bolts in the right places.
OR, you could buy 1 :tongue:
Just googling for one now.
Posted 09 August 2005 - 07:18 PM
Cant find one, but I guess most places sell them
Posted 09 August 2005 - 07:33 PM
Yea i'll try to make a shield, and for future knowledge its a 1.3/4 carb.
Its just i looked a bit silly today when it wouldn't start in the petrol station and i needed to push it out of the way!!!
Posted 09 August 2005 - 07:44 PM
:nugget: Of course its 1.3/4 :nugget: :fear:
44mm, 1.75 inch........
It does feel kinda stupid dont it :erm:
Its something you have to experience in life tho!
Posted 09 August 2005 - 09:12 PM
jimbo i have exhaust wrap on both mine and sarahs mini and never had a problem with this try it :cheese:
Posted 09 August 2005 - 09:16 PM
Yea i'll do both bungle just to be sure! Alan Jeffrey didn't find it too funny either when he tried to resart it after tuning it, he thought he must've broken something lol!!!
