hi guys , today i hooked up the clutch an slave and bled the sytem , my question is regarding pedal travel ,is it supposed to have a very short pedal throw?
the pedal only goes down about an inch or so is this normal or am i missing something ?
thanks
jon
Pro-mo Build Clutch Advice
YIANO
, Feb 01 2009 11:26 PM
2 replies to this topic
Posted 01 February 2009 - 11:26 PM
Posted 01 February 2009 - 11:49 PM
thanks
jon
AUP Jon
Well first things first (probably already done this) just check nothing is snagging etc! i have full travel as you are supposed to have as it is a normal mini setup after all pedal master & salve! then just check if you have the clutch arm in the correct position and isn't hitting the aperture in the suby!
then if all this is correct then you might have to take the master off & have a look at that! Replace or repair?!?!
All the best
Posted 02 February 2009 - 12:46 AM
its probably the clutch arm position then as the clutch slave cylinder is new.
so to recap, the arm should be at 45 deg at rest pointing to the large bolt holding the upper engine cradle, then pushed forwards towards the front of the car to disengage the clutch during pedal stroke downwards ?
thanks basky
thanks basky
