Im guessing you havent heard of WinSU
A program that allows you to enter engine spec and it will recommend a needle
also it shows graphs for each needle
You can also compare needles
www.winsu.co.uk/
hesitating on quick throttle up
gadgets23
, Aug 15 2005 10:10 PM
16 replies to this topic
#16
Posted 19 August 2005 - 09:57 AM
#17
Posted 24 August 2005 - 09:34 PM
arr thanks again ..
will defo try that SU prog !! ..see what i can find out about my needle !
tested the diaphram by just sucking on it .,.. if it pulls the plunger in and theres no leak then its fine
if it dont pull plunger in, OR u can constantly suck.. then its got probs ..
Mick ..
well went to MITP with current et up, and its much improved but theres defo still a small flat spot looks like a RR is really the only answerr
just costly, and not sure wers best locally !
Mick ..
