I had the same probs with the 1380. on idle the tempo would shoot up. And that was with a 4core alloy rad, oil cooler and elcetric fan. I went through all the usual stuff and changed my guage sender, voltage stabiliser, then changed to mechanical guage, all showed same temp rises.
I made sure it wasn't an air lock in water sustem. It wasn't.
I tried all sorts of fueling mixtures and timing adjustments. changed themostat, then tried with out one, all to no avail.
I then went to rolling road and got fueling and timing properly sorted and it was immediately apparent that it the temp problems were sorted. So I'd recommend that.
cooling a tuned engine
Purple Tom
, Aug 21 2005 09:46 PM
17 replies to this topic
#16
Posted 22 August 2005 - 10:12 PM
#17
Posted 22 August 2005 - 10:36 PM
every other engine i've built has used the hi-cap water pump, but for various reasons I couldn't source one this time round, so a standard one had to do.
Its booked onto Baldwins rollers on the 30th, so I'll see how it goes up until then.
Being concerned about 80 deg C is silly I know, I'm going to start cheap and replace the temperature sender before I do much else I reckon.
Thanks for all the replies so far, given me lots of ideas...
Tom
Tom
