Bike power
32 replies to this topic
#1 Rog
Rog
  • 12 posts
Posted 22 August 2005 - 10:59 PM
Hi Folks,
I'm new to this forum and I'm looking for advice. I have a '86 Chelsea that's going to be treated to a (much needed) rebuild with bike power. I'm aware of the Z Cars but while being an excelent piece of kit, it seems a little expensive. Maybe FWD bike power is a good place to start. What are the options? Any advice/comment would be very welcome.
Thanks in advance peeps.
#2 Alburglar
Alburglar
    Das Pingu's
  • 3,330 posts
Posted 24 August 2005 - 02:43 AM
www.rallysportreplicas.co.uk
He does a really neat fwd R1 kit
#3 R1mini
R1mini
  • 1,367 posts
Posted 24 August 2005 - 09:07 AM
Try buying one
David
#4 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 24 August 2005 - 09:23 AM
As with anything from Rallysport replicas sounds great! But whether you actually get anything for the money he takes of you up front is another matter!!!! :dontgetit:
Personally I would advise anyone not to touch them if you like either quality products or timley delivery!
Ade
#5 Mintec
Mintec
  • 45 posts
Posted 24 August 2005 - 06:47 PM
I'm with Ade,
Having taken my mini up to him from Bournemouth to use to take a mould from it for a carbon fibre extended front end (i have a vtec engine fitted using a Rover 100 frame) and believing him that it would take 3-4 weeks for a finished front end.
8 months later and hundreds of phone calls chasing him and he delivered the biggest pile of poo ever!!! and still no bonnet!!!!
He eventually sent the bonnet in the post and it got broken in the post!!! as he sent it with one sheet of bubble wrap and some brown paper!!!!
Rubbish!!! :nugget: :dontgetit:
Paul
#6 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 24 August 2005 - 06:58 PM
I was told the same from a friend too. Apparently the fwd bike conversion from there is literally thrown together scrapheap style :dontgetit: Im buying my next shell off a fella that is currently producing a fwd conversion. Hes been working on it for some time now due to his bizzy motorsport business but least he isnt just throwing it together. When I last spoke to him he said itll be using a tidy chain drive set up. Youll find a quick snip on www.lynxae.com. Theres also some pretty sweet A seires components he sells.
#7 Rog
Rog
  • 12 posts
Posted 24 August 2005 - 08:59 PM
Thanks for the info guys. I've taken a look at both sites and indeed and Rally Sport Reps have a lot to offer but judging by your experiences they seem to be spreading themselves too thinly. When I was at the Kit Car show in May I came across the Lynx stand and I was very impressed with their R1 GT car and indeed not just thrown together; it's just I'd rather stay away from chain drive. It can handle the power sure, but I'd like to fit it and forget it's there even if it does add a little extra weight. If only someone would flatter Quaife and make a cheaper version of their gear driven diff http://www.quaife.co...ogue/page85.htm. It is a quality piece of kit though and that almost never comes cheap. Anyone aware of such flattery?
Rog
#8 philster
philster
  • 1,255 posts
Posted 24 August 2005 - 11:18 PM
I wonder if there is anyway you could use a crown wheel and pinion off a mini gearbox and make some sort of housing for it all to sit in (with an oil feed etc.) That way you could use a standard diff with loads of ratios, or a four pin or even an lsd.
I realise it would take a bit of doing but would ditch the horrible chain idea.
#9 Alburglar
Alburglar
    Das Pingu's
  • 3,330 posts
Posted 25 August 2005 - 05:05 AM
They are around. One went on ebay for a couple of hundred quid a few months ago.
#10 Oldskoolbaby
Oldskoolbaby
  • 1,361 posts
Posted 25 August 2005 - 07:39 PM
That quaife diff housing looks sweet!! I bet if you were to fit that to an engine the lynx engine craddle will give you the perfect fit. All youd need then is some custom made drive shafts.
#11 R1mini
R1mini
  • 1,367 posts
Posted 26 August 2005 - 08:33 AM
Anything quaife will not fit in the front of a mini, unless you willing to extend it loads! especially the powertec quaife box totally wrong for a fwd mini in fact its far too big to sit in the back of a mini never mind the front.
If you use the mini crownwheel and pinion the bike engine will need to be reversed to go forward. This is the only way I have seen a sucessful install without chopping the standard front about see piccie attached
David
Edited by R1mini, 30 May 2010 - 04:09 PM.
#12 Rog
Rog
  • 12 posts
Posted 26 August 2005 - 03:00 PM
R1 Mini When I read your mail I thought, "[email protected], that's that then". But I've found this. It looks like a home-made subframe with an R1 block inc. Quaife LSD ATB diff. So there's still hope.
Me happy chappy
#13 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 26 August 2005 - 03:03 PM
I think you might find thats actually R1mini (dave's) car he's been working on for ages!!!! Having some trouble getting it all to fit under a standard front! :nugget:
#14 Rog
Rog
  • 12 posts
Posted 26 August 2005 - 03:04 PM
Here's a photo of them both together. It's hard to judge from a photo but that might also fit in the back of a Mini without major alterations.
Me very happy chappy.
#15 Rog
Rog
  • 12 posts
Posted 26 August 2005 - 03:06 PM
Ade, just read your reply. [email protected]!!!
Mini Spares
