~~~~~Please delete this text before posting the topic~~~~~~
Please give your topic a title that quickly describes your problem. Just putting 'Help my Mini doesn't work' is useless to anyone trying to help.
Model:1275
Year:1990
Hi, i have a 1275cc with a overheating problem can anyone help?
when running after around 5 mins the water starts to boil in the radiator, however the bottom of the radiator and bottom hose remains cold. Also the pipe that runs from the top of the head throught the bulkhead into the heater gets hot but the other pipe that returns from the heater to the pump area remains cold.
please please help as i hope it is not the head gasket as this has been done twice before.
Thanks for any help!!!!
Any non-standard parts that might be involved with the problem?
Overheating 1275
dazbo2001
, Mar 11 2009 07:22 PM
4 replies to this topic
Posted 11 March 2009 - 07:22 PM
Posted 11 March 2009 - 10:51 PM
I would 1st take the thermostat out and see if it makes a differance as it wont cost anything!
Posted 11 March 2009 - 11:05 PM
[quote name='dazbo2001' date='Mar 11 2009, 07:22 PM' post='1378043']
Model:1275
Year:1990
like he say check the thermostat and for god sake don't drive it until you
have sorted the problem as you may need to do the head again as it will warp it or blow the head gasket or worse crack the head .
remove the stat then refill any missing water and run for a short time if not hot like before that s were the problem will be, if its still hot and bubbling then you may find a blocked rad or a blocked chamber in the engine. but mor likly the thermo is the problem.
Model:1275
Year:1990
Posted 12 March 2009 - 03:38 PM
Thanks for the help guys, i'm going to try this tonight, i'll let ya know the outcome.
Posted 17 March 2009 - 02:27 PM
Hi guys, thought i had sorted this, but after i had changed thermostat and pulled the car out and on ramps i noticed it was smoking quite a lot and there was also spray of water coming out of the the joint on the exhaust below the engine(where it is blowing from).
Can someone confirm that its the head gasket? also would anyone know where i can pick up a decent head on the cheap, its a 1275
