ok....i've searched the forum and read what i could....but still have a few questions...
ok so i've part folded the a panel and lining it up with the door hinge...do i fully fold it around the hinge, and then just spot weld the top and bottom??
that doesn't sound like it'd be very strong though??
but the current a panel doesn't seem to have been welded all along the lip again the hinge...well actually....it doesn't look welded at all!
any tips? and also pics would be a definate help!
a panel help
frostie
, Aug 24 2005 11:16 AM
9 replies to this topic
Posted 24 August 2005 - 11:16 AM
Posted 24 August 2005 - 11:59 AM
correct, it's welded right at the top, on the A post, and right at the bottom to the sill, the rest s just crimped ( folded ) round... It should also be spot welded to the wing along the seam of course.
Posted 24 August 2005 - 12:05 PM
oh rite! doesn't seem like it'll be strong enough! ah well it must be!
i'm fitting a flipfront so seam doesn't matter!
cheers mate
cheers mate
Posted 24 August 2005 - 12:11 PM
You may wan to put a brace from the inner wing to the A panel just to help it, as normally the support is provided by the wing...
Posted 24 August 2005 - 04:03 PM
The "A" panel is welded at the top and at the bottom (as stated above) but it is also spot welded the the inner panel where it is crimped over , I usualy MIG tacks at regular intervals (about 1 inch) "A" panel crimped over bit to the hinge panel (door removed , well you have to to crimp it over!), be carefull not to weld where the hinges bolt to
Does that make sense ? it does to me but then i know what i wanted to say
Posted 24 August 2005 - 05:13 PM
ok so is this correct...
fold it around the hinge as tight as possible
spot weld top and bottom
and then spot weld along the edge at 1inch intervals??
Posted 24 August 2005 - 05:56 PM
from the factory it welded top and bottom and then 3 spot welds down the folded edge to the apost, i normally do 5 as i lke things nice and stong
dave
dave
Posted 24 August 2005 - 06:00 PM
Spot welds down the fold ? news to me, but maybe all the ones I've had off, the spot welds have never been apparent ( or even there any more ), probably too much rust !
Learn somthing new every day !
Posted 24 August 2005 - 09:10 PM
lol most of the ones i do these days dont have the bit for the fold to fold around
dave
dave
Posted 24 August 2005 - 09:31 PM
The last 3 I have replaced have come off in my hands :erm:
NOT good, seeing as 1 was only 18months old!
