Remote servo
12 replies to this topic
#1 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
  • Local Club: Blacktop Bombers
Posted 24 August 2005 - 04:34 PM
I'm about to get my hands on a remote brake servo, does anyone have one fitted that they could post up some pics of??
Also, are there re-build kits for them as this one is quite old I believe!
#2 dklawson
dklawson
  • 10,923 posts
  • Name: Doug
Posted 24 August 2005 - 04:54 PM
Mk1/2 servos are different than Mk3 and later. Rebuild kits are available, but you may have to go to places other than the usual sources like Mini Spares and Mini Sport. Contact some of the people who professionally rebuild brake parts. Mk3 servos are still available new and their rebuild kits are readily available.
You can see a picture of my engine bay and its servo at:
http://home.mindspri...ompartment1.jpg
#3 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,838 posts
Posted 24 August 2005 - 05:38 PM
I had one fitted, and removed it as it was a complete waste of engine space, plus I was going through clutches like nobodies business so it was for ever being taken out anyway...
But It was mounted on the O/S inner wing ( clutch side ) with the vacuum unit towards the bulkhead and angled upwards so the end of the unit was about where the bonnetstay bracket is located... then it was just piped in between the master cylinder and the down pipe for the brakes before the front/rear "T" piece. Take note that the vac pipe from the inlet must either have a 1way valve or U bend (below the unit) to prevent fuel being pushed into the servo..
#4 Pooky
Pooky
  • 5,691 posts
Posted 24 August 2005 - 05:43 PM
here's my servo
:smartass:
#5 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 24 August 2005 - 06:06 PM
Bling looking bay there my man, but that isn't a remote one. :dontgetit:
Maybe I will just get hold of a late type servo and change the barke system to suit, although they may already be the right ones?? I can't remember the differences without looking at a diagram lol
#6 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 24 August 2005 - 06:16 PM
Nice looking car you have there Doug, had a look through the rest of your site too - interesting stuff.
#7 bluebottle
bluebottle
  • 844 posts
Posted 24 August 2005 - 06:50 PM
i bought a new one a couple of years ago, but sadly on my car its buried out of sightin the dash above the heater.
i've got 2 old ones that are serviceable, so if you need pics of another one just let me know.
#8 Alburglar
Alburglar
    Das Pingu's
  • 3,331 posts
Posted 25 August 2005 - 05:10 AM
I'm putting mine in the passenger footwell in the minus
#9 Ade
Ade
    the bogie man
  • 2,357 posts
Posted 25 August 2005 - 08:32 AM
I've got one sitting in my garage! I pretty sure I'm not fitting it to my minus because I couldn't think of anywhere to put it :nugget: I didn't like the idea of it in the cab and there's not a lot of space under bonnet plus I'd have to run a vacuum line front the engine at the back..... :nugget:
#10 neil_g
neil_g
  • 880 posts
Posted 25 August 2005 - 08:55 AM
i'll be ditching my late 1992 servo and pedal box soon.
#11 Bluemini
Bluemini
    Mini Doctor
  • 4,436 posts
Posted 25 August 2005 - 10:05 AM
Do you need the correct pedal box to go with the satndard servo setup then?
#12 neil_g
neil_g
  • 880 posts
Posted 25 August 2005 - 11:43 AM
i think so, if i remember rightly the linkage is different through the bulkhead?
anyway ive got a non-servo early pedal box for free so ive refurbed it and im using that :dontgetit:
#13 minimadjonesy
minimadjonesy
  • 6,417 posts
  • Local Club: SMAC
Posted 25 August 2005 - 11:55 AM
if you fit the post 92 servo (the same type as pooky) you do need the pedal box to go with it! I've got one in the garage somewhere that is now surplus to requirements
