Anyone know the best type of filler to use for filling tiny holes and dents?
Any recommendations?
Filler
Will
, Aug 25 2005 10:39 AM
5 replies to this topic
Posted 25 August 2005 - 10:39 AM
Posted 25 August 2005 - 05:54 PM
Filler is NOT to be used for holes , only dents
I use "Isopon" mostly
"plastic padding"is good quality also
(as they say on the BBC, other good filler is available :grin:)
The cheap stuff of the market or from the discount car shop is POO and a false economy , it flakes ,chips , cracks,soaks up water (causing more rust) and is horrid to rub leaving "pin holes", it also sinks causing that "ice skating ring" look .
Posted 25 August 2005 - 06:02 PM
for small holes you require p40 from isopon or simular as for dents use aliumium filler then go over with a fine filler to finish
dave
dave
Posted 25 August 2005 - 06:06 PM
Cheers for that :grin:
Posted 28 August 2005 - 06:25 PM
:wales: see if any of ure mates family has a welder and just weld the hole file the weld down and use a little bit of filla to get it looking good
Posted 28 August 2005 - 06:44 PM
Im actually buying a welder so that's problem solved really. :grin: Cheers.
