Primary Gear End Float....
Posted 23 March 2009 - 07:39 PM
nearly got it all back together, thn checked the primary gear end float (why not, better late than never!!!) the gap is 0.3mm is this really bad?
how do I work out which new shim I need, haynes talks in mm and the mini centre i inches
please help
bob
Posted 23 March 2009 - 07:44 PM
Haynes shows both sizes. Find out what's it's ment to be, convert from metric to imperial. Done.
Posted 23 March 2009 - 09:05 PM
Posted 24 March 2009 - 06:56 PM
1.0" = 25.4mm. So to work back and forth multiply or divide using that. So - 0.3mm = 0.3 divided by 25.4 = 0.012". Yes that's bad. It should be 0.003" to 0.006" (0.003 x 25.4 = 0.076mm to 0.006 x 25.4 = 0.15mm). Often the extra large gap is caused by the front retaining 'C' clip wearing. This happens when you change gear, it bashes the primary gear up against the retaining washer which in turn whacks the C-clip. If you look at the C-clip you will see one side has grooves worn in to it. If you are lucky the other side will still be pretty flat - so just trun the C-clip around and re-measure. If it doesn't get the gap down, you will need to measure the bronze thrust washer to see what thickness it is and refer to one of the Mini specialists sites for alternative sizes. If yiou already have the largest or second to largest thrust washer, you will need to buy a new retaining C-clip and backing washer first - then re-measure and take it from there. KC
thanks, will retry the gap as you have suggested....will keep you posted
I had the thrust washer measured today it came in at 3.00mm ( strange coincidence that its0.3mm the gap!) so back on the maths that works out at 0.12"
just so I know what would too much end play manifest itself as...noise, rattle or worse?
cheeers
bob
Posted 24 March 2009 - 07:05 PM
worse...
Likelyhood that the bronze bush would ultimately disintegrate, taking the primary gear, crank, idler and gearbox with it... but that would take a while.
Posted 24 March 2009 - 07:17 PM
Primarily, you'd probably notice an excess of oil into the clutch housing past the primary seal, as the primary gear moves backwards and forwards depending upon load, as you carry on using the engine, the endfloat will progrssively increase and eventually....
worse...
OUCH!!, Had better get this right then!
thanks for your previous help, we're getting there i think....just taking forever!!
cheers
bob
Posted 25 March 2009 - 06:46 PM
so....
is my train of thought good?
can I get a thrust washer in this size, if so where from (998 mini)
cheers
bob
Posted 25 March 2009 - 07:28 PM
http://www.minisport...nfo_22A450.html
Terry
Posted 25 March 2009 - 07:30 PM
P/GEAR SHIM 998 118" 120"22A450
need to get this thing sorted, help please
cheers
bob
Posted 25 March 2009 - 07:48 PM
Gonna treat myself to a new C washer and backing plate as well
Posted 25 March 2009 - 08:02 PM
Yeah, I think so, I'm just about to order one as I'm in exactly the same boat!
yeah i hope so, i'm just a bit worried its not....come too far to muck it up now, if you know what i mean!!
Posted 25 March 2009 - 09:13 PM
MiniSpares has no stock, but MiniSport may have a 22A450 which is the thickest thrust washer for a 998 (.120) This combined with a C washer may get you within the spec end float.
Terry
