Hey all
rite blew up tweety on the motorway the other day. I took the engine out and fitted a metro unit today but the engine is seized. We think its sat for while but were not too sure (was told by the scrapper it was a runner )
So were in a right pickle!!!!
what can i do to free it up guys????
ive tried puttin it into gear, clutch in and rollin it but dat didnt work!
all the starter is doin is clickin which isnt good!
any ideas!!!
cheers
seized engine
tweety
, Mar 13 2004 06:26 PM
5 replies to this topic
Posted 13 March 2004 - 06:26 PM
Posted 13 March 2004 - 06:41 PM
If the engines been sitting outside, water can go into the carb and then into the bores.
This creates rust and can fuse the pistons to the bores. That is what happened to this 998 that I recently aquired, only in my case the engine was standing only a couple of months and the damage was minimal...
If the engine is proper seized, then there isn't much you can do. I'd go have a chat with that scrapper!
Posted 13 March 2004 - 06:42 PM
shame bout your car :gasp:
What exactly happened?
hope you get her runnin' soon!
Posted 13 March 2004 - 08:05 PM
might have been a runner when it arrived at scrappy but how long had he had it for..
have you tried putting a large spanner on the bottom pulley to see if it turns that way...
also are the starter motors the same, if not you need the one from the metro..
:wales:
:wales:
Posted 13 March 2004 - 09:40 PM
Is the starter jus clickin because u got a bad connection on the power line somewere? Take the starter out and make sure that it works ok...
Posted 20 March 2004 - 12:35 AM
Check that you have used the correct bolts in the clutch slave cylinder.
If they are too long they lock the flywheel
Siggy
Siggy
