Mutley - 1988 City
121 replies to this topic
#16 alexcrosse
alexcrosse
  • 3,786 posts
Posted 11 May 2009 - 09:50 AM
lovin that LED idea *goes to maplins now and buys LED's* think ill put them on mine, i want mk2 lights on the back which i have in the cuboard but need a reverse lamp, and with that little idea ill be able to do it, include a little reverse cluster. Mint.
Good luck with the project,
Cheers,
Al
#17 Icey
Icey
  • 1,491 posts
Posted 11 May 2009 - 10:19 AM
Al,
You will spend a small fortune buying the LEDs from Maplin. I suggest you search around and if you can wait then buy them from HongKong as they are pennies instead of the pounds that Maplin and such charge :D
Icey
#18 THE STIG
THE STIG
    Da stig says, GO GO GO
  • 2,506 posts
Posted 11 May 2009 - 01:39 PM
dont know if you have seen the mod they do to the standard gear linkager that means you only need a simple round hole in the bulkhead rather than cutting the big square hole
http://www.16vminicl...pic.php?t=14662
Edited by THE STIG, 11 May 2009 - 01:41 PM.
#19 Icey
Icey
  • 1,491 posts
Posted 23 May 2009 - 08:47 AM
Etch primed - HURRAH! It's only taken god knows how long for us to finally get here.
#20 craig 1010cc
craig 1010cc
  • 1,165 posts
Posted 23 May 2009 - 06:03 PM
Llooking good >_< how long before the colour goes on?
#21 Jackman
Jackman
  • 4,053 posts
Posted 24 September 2009 - 07:37 AM
Any updates? :wub:
#22 Icey
Icey
  • 1,491 posts
Posted 20 October 2009 - 02:24 PM
Well, we've moved house and still managed to make progress.
Here are a few pictures.
Stone chipped floors/boot
Masked the body. Sprayed Roof.
Masked Shuts, Sprayed Interior.
Took masking paper off.
#23 kcchan
kcchan
  • 874 posts
Posted 22 October 2009 - 09:59 AM
Make sure you can get enough movement from the gear change to select all 5/6 gears. It was a mod I wanted to do with the mini gear change but could get enough sideways movement from it. Your progress looks good though.
Also Im sure the lights have to be E marked to be legal. Something along those lines anyway.
#24 Icey
Icey
  • 1,491 posts
Posted 31 October 2009 - 06:49 PM
Oops, haven't updated.
Here are a couple more pictures.
Rear Arches:
Passenger Door:
F/G Bootlid:
Sun on the colour:
This weekend it's the other door, back of the bootlid and then the car :D
And todays update:
And today....
#25 minimininut
minimininut
    Look Out For My Haynes Minature Engine Install Project
  • 830 posts
Posted 31 October 2009 - 08:28 PM
Looking beautiful!! :D
#26 Icey
Icey
  • 1,491 posts
Posted 01 November 2009 - 02:49 PM
Thank you :D
Have a few more pictures with the paper pulled off!
#27 Midas Mk1
Midas Mk1
  • 5,641 posts
  • Local Club: S.U.N.M.C
Posted 01 November 2009 - 02:59 PM
mmm.... Orange'n'Black , Very Nice!! :D
#28 Sir Cheat
Sir Cheat
  • 1,171 posts
Posted 03 December 2009 - 03:43 PM
Ummm...Very tasty! yumyum
#29 Icey
Icey
  • 1,491 posts
Posted 03 February 2010 - 04:25 PM
Mutley has his very own private garage now and only a metre from the house - lucky boy. However not much progress has been made on the actually shell - need to buy a headlining, so then the windows can go in and so on and so forth.
Progress has been made on the electronics/electrics, a few pictures to wet you appetite.
Oh, first here is an outdoor picture before he got moved!
Edited by Icey, 03 February 2010 - 04:26 PM.
#30 Icey
Icey
  • 1,491 posts
Posted 29 September 2011 - 10:05 PM
Quick (and long overdue) update:
Front subframe is complete, hubs are built (4-pot vented brakes). Rear beam and swing-arms are also fitted.
With a bit of luck, in the next month he'll be back on four wheels for the first time in years.
