Finally, we could fit 17th sprocket, and 27 step chain by loosing diff case before. By the way, anyone knows max speed with 10´wheels at 11.000rpm?
Now, a Tranex LSD has been fitted in too.
Edited by lotusv6seven, 15 October 2009 - 03:45 PM.
Posted 15 October 2009 - 03:43 PM
Posted 22 October 2009 - 02:12 AM
Hi guys
Edited by Monte Busa, 22 October 2009 - 02:18 AM.
Posted 22 October 2009 - 02:17 AM
Hi guys
Edited by Monte Busa, 22 October 2009 - 02:19 AM.
Posted 22 October 2009 - 03:05 PM
Posted 22 October 2009 - 04:22 PM
I expected that. It´s fair enough for a small and twisting track as Guadix.
Many thanks. I guess 18t sprocket rise to 110-112 MPH...
Posted 23 October 2009 - 12:24 AM
Posted 23 October 2009 - 12:51 AM
"quote"I use 3rd, 4th, 5th, and 6th gear on that track (Waterford Hills Raceway, in Clarkston MI, USA
Do you ever go up to the Canadian tracks? I spent some time working at Mosport and might be able to get us some track time next summer if you are interested. We would run with the BMW club. Tremblant Is also a possibility. It would be nice to have a reference once I'm done my build.
Posted 24 October 2009 - 07:35 PM
Edited by lotusv6seven, 24 October 2009 - 07:41 PM.
Posted 25 October 2009 - 04:19 PM
Hey Monte Busa, good video.
Apparently, car is runing smoothly (just apparently) but it looks very quick and gearing works!. What about your setup? I don´t get a good setup so car is brisk and jumping all cornering. I´ve tried with tyres pressures but it doesn´t work as I´d liked it.
I´ve also realised you have not problems with gear level, short way, very accuracy. Are you using promo wire? Mine doesn´t work as properly as I need!
Finally, excuse me all asking together, what kind of tail exhaust pipe are you using? Motorbike? Mine has a mini´s but I´ve heared bike can could give me 5-8 HBP more...
Edited by Monte Busa, 25 October 2009 - 04:21 PM.
Posted 26 October 2009 - 01:47 PM
Posted 27 October 2009 - 12:35 AM
Thank you for tips!
New setup for next trackday and I´ll tell you how it works.
Car uses dunlop slick tyres. I used to drive with Miglia´s recomendations, 30 psi front, 28 psi rear, not warm.
I´m not quite sure 16 psi warm. It looks not enough pressure. Anyway I´ll try if setup doesn´t work.
Edited by Monte Busa, 27 October 2009 - 12:37 AM.
Posted 09 May 2010 - 04:43 AM
Posted 10 May 2010 - 08:57 AM
Hi guys - have you had any isses with your jack shaft / diff box input shaft? The splines on mine are almost 30% worn through with only 600 miles on the clock....hmmmm. Checking with the pro-mo boys about it....
Edited by lotusv6seven, 10 May 2010 - 08:58 AM.
Posted 10 May 2010 - 09:11 AM
Posted 22 May 2013 - 10:31 PM
