I have just done this conversion, i have two light green wires that are terminated at each end with male and female spade connectors, they go back into the loom and come back out again. They are used to connect to the regulated 10v supply from the voltage regulator and the fuel / temp gauges. You will also have a two white wires one connects to the voltage regulator input and one goes to the ignition warning light. I connected both to the white wire (switched live 2nd key position) that goes into the old multiplug connector. Did you find that the indicator light flashes when using the indicators but not the hazards? i am trying to solve this with some diodes and rewiring, (after my exams are finished!) i will let you know how it goes.
That sums it up better than I did
For clarification, the indicator warning light doesn't flash with hazards because one terminal on the bulb connects to the offside indicator lamp circuit and the other to the nearside circuit. When you indicate left, the warning bulb's effective earth is through the right hand indicator circuit and vice versa when indicating right. When the hazards are activated, both the right and left circuits are both live at the same time, causing a negligible voltage across the indicator warning bulb so it won't light up. I'll be interested to see how you manage to get around this with diodes etc... let us know!
