Mini....with Chain Motor Engine.....
#46
Posted 24 June 2009 - 02:01 PM
full open 38cm
full close 28cm
10cm travel...
the spring do not write nothing
#47
Posted 24 June 2009 - 02:08 PM
about 3cm for the bushing at the bottom?from center to centre (bolt)
full open 38cm
full close 28cm
10cm travel...
Also, what's the diameter of the coil spring?
#48
Posted 24 June 2009 - 02:14 PM
i do not understand th other you want...
#49
Posted 24 June 2009 - 03:38 PM
the rubber bushing that you pushed to the bottom of the shaft, the shock body will hit that at full compression, I was wondering how thick it is....78mm diameter...
#50
Posted 24 June 2009 - 04:09 PM
the 10cm travel is with the stop on...
i will measure that and i will write to you.....
Edited by sotiris, 24 June 2009 - 04:10 PM.
#51
Posted 25 June 2009 - 01:29 AM
#52
Posted 26 June 2009 - 02:51 PM
money money money......
#53
Posted 07 July 2009 - 06:47 PM
lolol
Edited by sotiris, 17 October 2009 - 01:47 PM.
#54
Posted 09 July 2009 - 03:16 PM
#55
Posted 09 July 2009 - 11:38 PM
#56
Posted 10 July 2009 - 09:09 PM
i want to look nice like this....
Edited by sotiris, 10 July 2009 - 09:10 PM.
#57
Posted 13 July 2009 - 11:57 PM
(all these crazy foreigners wanting to build bike powered Mini's... , I am doing the same in the Netherlands)
#58
Posted 15 July 2009 - 12:05 PM
nice fit .......
Posted 16 July 2009 - 05:51 AM
the other week will post pics....
#60
Posted 23 July 2009 - 09:29 PM
and the heart of the project........
but it give me new questions........
first.... hydraulic clutch, what must i make to work with thw petal.... must i buy a oem hydraulic from suzuki parts and patent this.....?
second...... gear ratio..... how many tooth front and how many rear gear.... i do not want top speed.....i want good power for 400 meter.... 125 miles i think is very top for me......
the engine is from b king 2008 1340 and the wheels are 175 50 13'' x 7''
third fuel pump.... and fuel pressure what preasure ????..... i will buy a Bosch pump and a fuel regulator
but what about the fuel level float "sensor"?????
fourth the engine instruments (gauges) is broken... can i buy an aftermarket without problem ??? ...i saw that some of you have nice instruments.....were can i find this.....??
Edited by sotiris, 23 July 2009 - 09:42 PM.
