its the upper ball joints you have to watch!! you need to have an inch or 27mm of movement in the supension before you hit the bump stop or you may well break the upper ball joint. if you want to lower the car more try removing the spacer to the body and subframe.
around 15mm gap from top arm and bump stop...... is 25mm wheell move up-down...
is that corrent ??
Edited by sotiris, 23 October 2009 - 06:11 AM.
