Hey folks, the brakes on my mini are causing a few problems.
It appears that the master cylinder spring is not releasing the pressure off the brake system and is causing the brakes to lock on when used for lots of heavy braking, IE on the ring. Whenever the master cylinder is hit with a hard object something seems to free itself and the car is then free to move. If the brakes are not used for a long period of time, the cylinder does also free itself. It is a dual line system from a 72 car, using Metro 4 pot non vented calipers and solid disc, on the rear it is spacered drums.
It is only the front brakes locking up as i have jacked up the rear of the car and the drums rotate freely when the fronts are stuck
Anyone got any suggestions? Rebuild the cylinder?
brake problems
Madmax
, Sep 08 2005 03:50 PM
7 replies to this topic
Posted 08 September 2005 - 03:50 PM
Posted 08 September 2005 - 04:01 PM
James do you have a pic of the master cylinder? If you do I could compare it to the spare one I have, and if its the same I could send it with the wiring loom?
Tom
Tom
Posted 08 September 2005 - 04:03 PM
i can get a pic, but not for a while, havent got a card reader and ive lost my bluetooth dongle
can you post up a pic of yours so i can compare?
Edited by Madmax, 08 September 2005 - 04:04 PM.
Posted 08 September 2005 - 04:05 PM
just found one
Posted 08 September 2005 - 04:19 PM
I have one of those spare, its the original one from my car, and I know it works, if you want it?
Posted 08 September 2005 - 04:22 PM
i do indeed mate, consider it a swap for the console?
Posted 08 September 2005 - 04:26 PM
cool, well i'm going to the show at Stanford Hall and may pick up a console from there, and if I do then just call it a tenner on top of the loom?
Posted 09 September 2005 - 12:16 AM
yeah cool, whatever mate, the consoles there if you want it
