just a quicky, just fitted the rev counter i bought back last year!!!
i have all the wires in place, just im not sure what side of the coil i need to take the source from!
thanks
aaron
Rev Counter
mini_ron
, Sep 10 2005 09:53 AM
3 replies to this topic
Posted 10 September 2005 - 09:53 AM
Posted 11 September 2005 - 10:53 AM
any ideas anyone?
will i break anything if i use the wrong one?
aaron
aaron
Posted 11 September 2005 - 04:46 PM
Assuming negative ground, the rev counter wire would go to the negative side of the coil. You won't damage the coil or rev counter if you connected it incorrectly it just wouldn't work.
Posted 12 September 2005 - 02:09 AM
As Blue said, on late model cars with negative ground the connection is typically on coil (-). This is the side of the coil that is connected to the distributor.
