help.
4 replies to this topic
#1 Lora222
Lora222
  • 106 posts
Posted 12 September 2005 - 01:40 PM
had my mini out yesterday, when i was slowing down and braking to go into a 40mph speed limit, it just died, the engine was still running, i tried pumping the accelerator pedal and nothing happened, eventually it cut itself off so i rolled to a stop, tried to start, nothing! checked the fuel lines etc everything was ok, it was getting fuel, has plenty oil, got the ignition no problem etc...
after a while of trying in desperate vain it started, and took it home no problem.
Surely it wasnt a fuel pump problem as that was replaced a while ago after this previously happening! although the last time it did not start at all afterwards, but was fine after another carb was fitted!
can someone please tell me what can be causing this? is it possibly too much heat?? we looked at the carb that i originally had and cant find anything wrong with it at all.
please help.
thanks
#2 Purple Tom
Purple Tom
  • 4,921 posts
Posted 12 September 2005 - 02:21 PM
what was the weather like when it happened?
#3 Lora222
Lora222
  • 106 posts
Posted 12 September 2005 - 02:29 PM
it was dry on both occassions, wouldnt say hot....
#4 Guess-Works.com
Guess-Works.com
    Gearbox Guru
  • 19,840 posts
Posted 12 September 2005 - 02:55 PM
My immediate thoughts are fuel starvation...
#5 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 12 September 2005 - 06:15 PM
two thoughts, fuel line damaged under the car, or battory cable shorting on the exhaust
dave
