I have a j plate rover mini with a 1275 conversion, the orange light on the dash will not go out till i accelerate if i let of the accelerater it turns back on, also when stopped at a junction the car now often stutters then dies.
Please help ive checked all the wiring and that seems in order !
thanks,
j :erm:
Orange light and stoping at junctions
minijohn
, Sep 13 2005 10:07 PM
9 replies to this topic
Posted 13 September 2005 - 10:07 PM
Posted 13 September 2005 - 10:12 PM
The oil pressure light? Have you checked the oil?
Posted 13 September 2005 - 10:15 PM
yes lol it has plenty of oil
Posted 13 September 2005 - 10:37 PM
the orange light indicates oil pressure. With a standard oil pressure switch it goes out at roughly 3-4psi I believe.
A good engine when hot should idle at at least 30-35 psi really, maybe a bit less if very hot.
I'd change your oil pressure switch soon, and see if it still occurs. If it does, then it may be time to start looking at an engine rebuild, as it should be managing more than 3psi at idle. Chances are the main and big end bearings and the oil pump are worn.
Do you know if the engine has an uprated oil pressure switch, set to come on at 22 psi?
What sort of revs to you need to reach before the light goes out?
To prevent the stuttering and stalling as a temporary measure you can turn the idle up a bit, this will hopefully cure that, but the engine might need a good tune if it has any performance bits fitted.
But get that light investigated, it is NOT GOOD for the oil pressure light to come on at any point when driving.
Posted 13 September 2005 - 10:52 PM
cheers i know the engine is heavily race modified err its goes out round 35 it was a complete rebuild 5 mnths ago
oh deary seems trouble looms.
Posted 14 September 2005 - 06:51 AM
I'd be fitting an oil pressure guage, as only having the oil light on a performance motor is just waiting for dissaster...
Basically, unless the switch is f**ked, then your engine will be.. certainly new bigends, and mains, and you'll be realy lucky to get away without regrinding the crank...
Personally I would not be driving it anywhere in that condition.
Posted 14 September 2005 - 08:14 AM
I had the same problem with my J plate cooper, found out the oil was the wrong grade some plonker put 5w30 in it.
try dropping the oil and put 20w50 in it and see this solved my oil pressure problem.
it is worth putting a oil pressure gauge on the car too.
as for oil try the tesco value oil its cheap and not bad quality only 94p a litre.
Posted 14 September 2005 - 10:25 AM
what the chap above said!
If its not hold oil pressure it could do with an oil change
Posted 14 September 2005 - 01:38 PM
Also check the oil pressure relief valve this may be stuck open.
its may be worth changing this to a ball bearing type that mini spares sell
Posted 14 September 2005 - 08:29 PM
Change the filter while you are doing the oil
