the fuse for the wipermotor and heater keepes blowing each time i use the wipers. i have narrowed the problem to the earth cable not wired to the wiper motor. does anyone know where you attach the eath wire on the motor, there arent any marked points on my wiper motor.
any help appriciated
thanks
Tam
wiring wiper motor
tam0123
, Sep 15 2005 11:58 AM
4 replies to this topic
Posted 15 September 2005 - 11:58 AM
Posted 15 September 2005 - 12:06 PM
there should be some very small (2BA?) bolts that are screwed into the wiper motor body, they hold the outer plate on.
Remove one and refix it with your earth wire attached, then earth the wire to the inner wing or bulkhead.
Should do the trick.
Posted 15 September 2005 - 02:08 PM
I always thaught the Wiper motors earthed onto their mounting point (the scuttle pannel)...
You sure the live is not shorting on anything?
Posted 15 September 2005 - 02:10 PM
There's a small rubber pad which they sit on (right underneath the motor body), so they do need another earth.I always thaught the Wiper motors earthed onto their mounting point (the scuttle pannel)...
Posted 15 September 2005 - 06:10 PM
i dont think there is any other fault or atleast as far as i can tell. there is a black cable that was hanging loose on one of the small bolts on the motor thats why i asumed it was earth. connected it to the body panel so will see if the prob occurs again.
