Rear Disc Brake Convertion
#16
Posted 17 July 2009 - 11:25 AM
Its bling yeah, but most people only buy bling for there mini if its cheap enough. Remember these are hidden behind wheels, so how many people are going to notice that bling....?
I agree that its the weight that matters, KAD list the weight of theres on the website, would be nice to see a comparison once you have found a caliper etc. Its about unsprung weight, I can see the kits been popular with track or road/rally/track cars.
#17
Posted 17 July 2009 - 02:51 PM
You can already get alloy hubs for a lot less than a full disc brake conversion.I wouldnt say lightness is the main factor either to be honest.
id buy them because they are nice strong billet hubs with the extra peice of mind that you have disks on the back
plus they look awesome mate well done!
Having discs on the back won't help the braking in anyway.
Which leads me back to my original point, if the setup doesn't end up being that light, the only point is the bling. And if the price comes out anywhere near that of the KAD setup, who is going to pay near on £600 just for a bit of bling that hides behind the rear wheels most of the time?
#18
Posted 17 July 2009 - 06:11 PM
Guess we will see.... At the moment I can see this being around the £400 mark just for the record
#19
Posted 17 July 2009 - 06:12 PM
#20
Posted 17 July 2009 - 06:42 PM
#21
Posted 17 July 2009 - 07:42 PM
If I were looking to fit rear discs*, then I would be happy to pay strong money to a proven manufacturer for an all-inclusive kit that remains road legal. However, buying something from an amateur (no offence meant) would have to be significantly cheaper for me to justify it.
* I would never even consider putting discs on the back of a mini - road, race or rally spec.... Unsprung weight is the ONLY advantage to a decent rear disc setup, so someone with a circuit racer looking to save weight might be interested. For road use, disc brakes are complete overkill, and IMO far too many people just assume that better brakes on the rear is a good thing. The fact is that unless they are used with an adjustable bias valve and set up very carefully, overall braking performance will be seriously compromised and the safety of the car is called into question.
#22
Posted 17 July 2009 - 07:49 PM
#23
Posted 17 July 2009 - 08:12 PM
Alan...
#24
Posted 17 July 2009 - 08:48 PM
1) Im not an amateur (not offended just dont want to put people off), I run a engine building business kitted out with all the right kit to get the job done properly
2) I already have the correct insurance for this situation. Thankyou for your advice though
O, and dont you think £300 if a significant price difference
Cheers Guys
Edited by 01smartc, 17 July 2009 - 08:50 PM.
#25
Posted 17 July 2009 - 09:19 PM
Alan...
#26
Posted 18 July 2009 - 09:38 AM
Hopefully yes, but not always the case. I've had several cars now with disc brakes all round, and on many of them the rear discs aren't used enough to keep the pads and discs clean and working effectively. The result is that sometimes you need to give the pads and discs quite a rigurous clean in order to get the handbrake working sufficiently for the MOT.The other advantage of disk brakes would be that you wouldnt have to adjust them all the time, which if you do a few miles gets a bit boring. But then again I wouldnt pay hundreds just to not have to adjust my drum brakes
#27
Posted 19 February 2017 - 11:02 AM
Did you ever finish this rear brake set up ??
#28
Posted 19 February 2017 - 02:53 PM
#29
Posted 19 February 2017 - 05:56 PM
The rear brakes on the Mini only do about 20% of the total braking so discs are not necessary. Getting pads soft and/or small enough to work is difficult.
Totally agree. I've saved a bit of weight with superfins, they also add a bit of "period" bling. If I wanted more bling and weight saving I would be upgrading my arms and back plates to billet items. But I'm not !!
I think people going for discs are either totally after bling or are under the misconception that they are under braked and see this as a real performance upgrade.
#30
Posted 19 February 2017 - 06:49 PM
