Plus this was made my smart performance. remember the malarkey with them? stick to minifins!
Rear Disc Brake Convertion
#31
Posted 19 February 2017 - 06:59 PM
#32
Posted 19 February 2017 - 07:07 PM
To get to the correct working temperature on a Mini, the disc brake would need to be around the size of a small motor-bike's front disc brake.
#33
Posted 19 February 2017 - 08:43 PM
#35
Posted 19 February 2017 - 09:41 PM
Quite a few modern smaller cars still operate on rear drums out of the factory and they tend to have more powerful engines than what you'd get in a mini and more weight to stop.
#36
Posted 19 February 2017 - 09:47 PM
#37
Posted 20 February 2017 - 12:27 AM
Tbf there are people running huge amounts of power compared to when this argument about rear discs on a mini started in the 80s. Some of the sub 4 second 0-60 minis could probably make good use of them?
True, But Toyata have the Tacome for sale with a 3.5l v6 and drums. Heft front brakes mind similar to what youd expect if you seriously upgraded the power of a mini.
#38
Posted 20 February 2017 - 01:05 AM
How? Most of them have the regulators set to just about turn the rear brakes off. A locked brake gives no braking power.Tbf there are people running huge amounts of power compared to when this argument about rear discs on a mini started in the 80s. Some of the sub 4 second 0-60 minis could probably make good use of them?
Discs need heat to get them working. The rear brakes just don't really do enough work to get warm.
Reducing weight sure they can be lighter.
But with alloy back plates, hubs and the good old superfin drums you won't be far off that either.
#39
Posted 20 February 2017 - 03:01 AM
I've done a couple of conversions. The standard brakes for what and where they are are quite adequate and that's not why I did mine.
My reasons were for a much lower maintenance brake set up, a reliable handbrake and something that didn't need a major rebuild after every creek crossing. I got ticks in all boxes.
#40
Posted 20 February 2017 - 06:49 AM
Reliability is kinda what I was thinking with my post. I have never dealt with a "modern" drum brake, I understand they are self adjusting? How does this work? Is this something that could be implemented on a mini?
#41
Posted 20 February 2017 - 07:13 AM
It's a ratchet system. Very simple if you look into it. However, as most of us are under the car and service them often, it doesn't take five minutes to manually adjust.Reliability is kinda what I was thinking with my post. I have never dealt with a "modern" drum brake, I understand they are self adjusting? How does this work? Is this something that could be implemented on a mini?I've done a couple of conversions. The standard brakes for what and where they are are quite adequate and that's not why I did mine.
Edited by Steve220, 20 February 2017 - 07:15 AM.
#42
Posted 20 February 2017 - 05:19 PM
#43
Posted 20 February 2017 - 07:34 PM
I can't understand why taking the rear brakes up is any kind of an issue. You simply do it every time you grease the rear trailing arms and check the tyre pressures. It takes about 30 seconds per side. You can't have an old classic and make it low maintenance.
I didn't mean to offend and don't find it a real issue, however some people like to try and make improvements and engineer solutions. If someone wants to re-engineer the rear brakes but discs aren't viable due to temperatures etc then I just thought that modernising the drums to make them self adjusting may be an idea.
#44
Posted 20 February 2017 - 10:55 PM
On the Cortina GT's from late 1965 the self-adjusting rear brakes never worked well and the modification was to fit the earlier manually adjusted ones. It really is a simple job. I can take mine up during a rally without jacking the car up whilst waiting to start a special stage if necessary. The rear drums and pressure limiter valve is designed for the Mini and to cater for the amount of braking required on the rear. The handbrake works well and as there is so little braking done by the rears they are absolutely fine as they are. The only issue is the unsprung weight if racing and for this lightweight arms and alloy drums are available.
Changing the rear brakes is more than just machining up some nice-looking bits and bolting them on - they need to get to the correct temperature, apply the required braking effort, provide a handbrake capability and be reliable. What calculations have the vendors of these rear discs done? If they have, from whence did they get their base-line braking figures?
#45
Posted 20 February 2017 - 11:01 PM
And that is a sporty 1000kg modern supermini.
