When I circuit raced Mini's we used to adapt the rear limiting valve - shortening the spring and fitting a bolt through back end to adjust it.
Then set it so that with a heavy foot on the brakes you could just about turn the rear wheels.
This was enough to satisfy the scrutineers and the blue book "4 wheel braking system"
Used Minifins for the least unsprung weight with drilled alloy spacers.
