ok my dads driving cant be this bad but he accselerates and if he comes of throtle qwickly shudder and the gear jumpes outa place what could be wrong ?
also is a central oil pickup worth geting / what they do ?
GEARBOX PROBLEMS
Sutty01
, Mar 19 2004 09:08 PM
6 replies to this topic
Posted 19 March 2004 - 09:08 PM
Posted 20 March 2004 - 12:30 AM
Check the engine stabilser bar, its on the drivers side by the
clutch master cylinder.
If you want to fit a central oil pick up you need to strip the gearbox to do it. But well worth it. No more loss of oil pressure going round corners
Siggy
Siggy
Posted 20 March 2004 - 09:34 PM
does this happen in all geas or just the one?
jumping out of gear usually means a worn gear, basically the teeth on a spcific gear are worn down and need replacing. :sad:
Posted 21 March 2004 - 10:07 AM
the chances are its in second, the most commonly worn gear. if so u will be looking at a new gear, or usually easier jsut bolt a re-con box on from a show, usually around £150-£200.
as for a centeral oil pickup pipe, id say its a must if u drive round right hand corners or roundabouts fast! again means taking ur gearbox off, but isnt the worst job in the world to do
Posted 22 March 2004 - 01:06 PM
so roughly whats involved in doing a centeral oil pickup?
Posted 22 March 2004 - 08:07 PM
Full 'box strip and re-build... Not for the faint hearted!!
Posted 22 March 2004 - 11:30 PM
Unles you have a centre pick up don't fit A032s and an Oil pressure gauge.
Its scary watching the ol pressure drop on corners!!!!!!
Siggy
Siggy
