hi all, i need to buy a new gun, after i never cleaned my old one properly after the last car i painted
i prefer the gravity fed ones, (seem to work better with them for some reason) but anyone recomened a good gun?
ive been looking at sealey, are they any good?
which spray gun
ian
, Sep 22 2005 05:25 PM
2 replies to this topic
Posted 22 September 2005 - 05:25 PM
Posted 22 September 2005 - 06:25 PM
i use devilbiss in work, but they are £380 per gun. if you are using it ocasionaly, sealy should be ok, but with most things, get the best for what you can afford. have a look in machine mart, i use one for my primer gun and that seems fine!!!!!!
Posted 22 September 2005 - 07:39 PM
a tip for you!!!!! cleaning ! go to a dulux trade centre! and ask for brush mate fluid clean your gun in this ! its very good but remove all rubber! seals firsthi all, i need to buy a new gun, after i never cleaned my old one properly after the last car i painted
oh and try dedicating your guns to a spec jop as you should re jet your gun to suit either primer aor a top coat paint as they all hold diff vicosities! and your finish will suffer !
i use same brands as BMM and they are well worth buying !
