Ken -The 1275 High Compression Engine Micra Mini (Running Project)
749 replies to this topic
#1 lawrence
lawrence
  • 1,330 posts
Posted 19 September 2009 - 12:30 PM
This is the long running blog I have for my Micra Mini.
This is a breakdown of what this blog entails. So you could call this the contents page sort of
Page 1- Initial strip down to highlight the areas that needed fixing
Page 2- Wiring strip down, NS sill removal, welder bought and first bit of welding on the NS inner sill
Page 3- Welding of NS floorpan, doorstep, wing removal, scuttle repair, new NS sill - inner wing made ready for new outer wing, Welding of OS floor pan, sill and inner wing - inner wing made ready for new outer wing, rear subframe removed- OS boot corner welding and deseaming of boot lip - OS heelboard repair - roof hole welded
Page 4- NS boot corner welding, NS rear bin repair, panel delivery, front end bumper lip removal, NS flitch repair, NS wing trial fit.
Page 5- NS heelboard repair, OS door skin removal, wiring new fusebox and Daewoo column stalks, OS A panel fitting, OS wing welded on, OS door step repair, OS wing sealing and paint.
Page 6- NS sill welded, boot lip repairs, half of rear valance fitting, radius arm rebound stop area repaired
Page 7- Rest of rear valance fitted, boot inside painted, boot outside painted and undersealed, inside floor painted, filling Rear end, NS wing made ready to fit, few mods to the front panel by taking off latch parts and smoothing areas,
Page 8 - NS a panel and wing fitted, sealed and painted, front end prepped for respray (that never happened
Page 9- Bonnet fit adjusted, some parts fitted back to front end, more paintwork in places, rear subframe investigated and decided to replace, modified inlet manifold and carb for better flow, repaired doors ready for skins
Page 10- More door flange repairs, new second hand subframe bought and painted, waist rails repaired both sides in and out
Page 11- Internal boot hinges made, engine bay repaint, new front rear brake line, engine bay built back up, NS rear wing welding finished, petrol tank mods for internal filler, rear subframe built up and fitted, car rolled outside for photos, lamp bar made and fitted, interior refitted with help from Lambert (RIP Puss cat), Doors fitted once painted black.
Page 11- Last bit of body welding on OS rear wing, filling and painting, waxoyling, rear window fitting, testing the lights and wiring, more petrol tank mods,
Page 12- Interior mods- auto dipping mirror, suede seats, new headliner, more waxoyling, taken for mot (failed)
Page 13- Mot PASS June 2012, roof repaint and new windscreen, head gasket blew, off the road 16th august.
15 month interlude when no work happened
Page 14-14th Dec 2013 mot fail in the morning, fixed and pass in the afternoon. She was ready for the road Christmas Day 2013, HG change New Years eve, mini went with me to Norwich from my parents to live at my rented accommodation. megajolt system fitted, roller repaint of front, Micra bought. March 2014 start of the engine change, engines both out, subframe being made,
Page 15- Engine mounts, trial fit, frame painted, inlet mani made and carbs mounted, clutch done,
Page 16- Alternator mounted, gearstick sorted, exhaust fitted, megajolt done, engine broken, engine repaired, horrible air filter made, brake lines ran, body roller painted white,
Page 17- More paint and window tinting, suspension parts fitted, brakes all bled, exhaust being made,engine fire
Page 18- More interior mods, Oct 2014 Transported home to parents, helper cat 2 Harley (RIP Puss cat), new head gasket needed to be fitted (old one was caught), fun with soldering
Page 19- Paint, cam broke, fun with brass and soldering, problem with engine, valve broken, new engine sourced and fitted on drive.
Page 20 -
The post below was what I had first posted back in September 2009, I had owned ken senior for a few weeks when I made that post.
hey guys
ive gotta mini city that doesnt seem to bad, cost 1800ish
quite like some opinions about the work that i have to undertake
will add some piccies of the problem areas [
opinions would be nice about what i can do about them
thanks
L
here are the piccies of the target area. its not actually that bad lol it think it might be worth more thn 1800
<script src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/4a54ffd4/background/helpers/prefilterHelper.js" type="text/javascript"> </script>
<script src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/e38de114/background/helpers/prefilterHelper.js" type="text/javascript"> </script>
<script src="safari-extension://com.ebay.safari.myebaymanager-QYHMMGCMJR/b335793f/background/helpers/prefilterHelper.js" type="text/javascript"> </script>
Edited by lawrence, 27 August 2018 - 10:21 AM.
#2 Jim_Jam
Jim_Jam
  • 225 posts
Posted 19 September 2009 - 01:09 PM
Have you got a picture of the whole car? I'd be interested ^^
To decide what the car is worth you need to take into account mileage, edition, aftermarket kit etc. aswell as the amount of rust. Those spots don't look too bad, I had a spot like the one shown in your bottom left image on my bootlid, unleashed my angle grinder on it, took it back to bare metal, applied a little hammerite on a spot I didn't want to push too far, I'll prime it later on today ready to spray and laquer. It all depends on how deep the rust has gone and how much work you want to put into getting rid of the rust spots eg.cutting and welding vs. sanding and touching up. Looks like it needs a clean aswell. :)
Best of luck on the work, post on your progress! and most of all enjoy driving your new city. Have you named it or is this another mini with an identity crisis?
-Jamie :errr:
Edited by Jim_Jam, 19 September 2009 - 01:11 PM.
#3 lawrence
lawrence
  • 1,330 posts
Posted 19 September 2009 - 01:24 PM
heres some of the entire car, im gunna clean it all ready for it first day at college
additions to the car (not by me)
1991 metro gta 1275 engine replacement
ken air filters
electric fuel pump
ultra lightened flywheel
turbo clutch
maniflow lcb twin box performance exhaust system
quickshift
brigstone tyres
half cooper interior
kindwood sterio
kenwood tri mode amp
halogens
lear lensed all round
cooper quick release grill
chrome handels allroand
chrome bumbers
new brake pipes and hoses
tarox drilled n grooved didsks
new back standard brakes
gaz adjustable shocks allrond
new cones
hi lows allround
2 neg camber front
adjustable tie bars
neg camber rear subframe plates
oh and minis nickname is just mini lol
#4 Jim_Jam
Jim_Jam
  • 225 posts
Posted 19 September 2009 - 01:31 PM
oh my that is a VERY nice mini. I've seen it on here before can't remember where, maybe when you just bought it? The interier looks belta too.
How much is your insurance on that? (Assuming you've declared everything?)
I dont't have too much experience with white but I think its quite an easy colour to match when respraying patches.
#5 lawrence
lawrence
  • 1,330 posts
Posted 19 September 2009 - 01:36 PM
thanks, yeh i added some pics to my joing the forum thread :)
erm its 1600 ahh lol. thats me on my dads insurance for it but im the driver that most uses it. kinda difficult to get insurance for just me!! and it mostly all declared accept small things :errr:
hehe i thaught it would be easy to match but i dont know they tyep of white lol! thaught there was just white but no!
L
#6 Jim_Jam
Jim_Jam
  • 225 posts
Posted 19 September 2009 - 02:31 PM
Thats not a problem, look inside your engine bay and theres a plate with (I think its your vehicle ident. number?) and your colour code. For example the code for my solar yellow is 'FNH'. Have a deek. Once you have that you will have no worries getting the colour mixed. You know, £1600 isn't too bad, untill recently, I was paying £1500 which would cover half a year, once I did my pass plus that would go down to around £1100, after the six month I would get an accelerated 1 years no calims with them so it would roughly work out £2000 for 1 and a half years and atm mine is a standard 998! I searched high and low before buying insurance. I found myself a classic policy, so as soon as I pass my test (a matter of days hopefully) I'm cancelling that (I called to find out how much I would loose and its not a great deal to be honest, about the same as if I had only paid for provisional insurance) the policy will cover me third part F&T for a year, includes 35 days in europe and breakdown cover for £522!!! Thats just with me on the policy.
#7 lawrence
lawrence
  • 1,330 posts
Posted 19 September 2009 - 03:10 PM
haha its code NMH lol. whatever that means! i cnt get insure on a classic policiy becuase mini is like highly modified :D. but ive passed now and will be driving her form the 1st yay
L
#8 Ouster
Ouster
  • 2,986 posts
  • Local Club: Looking
Posted 19 September 2009 - 03:15 PM
Yes you can.
#9 lawrence
lawrence
  • 1,330 posts
Posted 19 September 2009 - 07:27 PM
believe me ive tried all the people i could find, they either costed like 3 k or wouldnt insure me because im 17 :D
#10 lawrence
lawrence
  • 1,330 posts
Posted 19 January 2010 - 09:15 PM
hello again people,
poor little mini (now named senior) is coming off the road from thursday due to insurance problems and wont be back till the 5th of march (my 18th, yay)
this means that i finally have some time to fix her rust spots!! :D
im also servicing her completely with an oil change etc and changing her ball joints during this time with possible replacements of them all, fun fun :D
ill be adding pictures on friday of how she looks now :techsupport: probably with some tears in my eyes O_O
so have a look at the progress i make (theoretiaclly) if you want, ill try and do updates about what im doing
Lawrence
#11 lawrence
lawrence
  • 1,330 posts
Posted 14 May 2010 - 10:35 AM
hey people, this is my first actuall proper update,
she didnt come off the road in the end due to the massive cancelation fee that i had and the problem went away which is good.
i have however been attacking her slightly
these are the pictures of the damage so far, some are upside down due to the sun
i also got her some new wheels and alloys, and am worndering what people think
today ill be attacking the door and its lovely rust, thinking sanding down, krust, then primer and paint, sound ok?
Edited by lawrence, 14 May 2010 - 10:49 AM.
#12 lawrence
lawrence
  • 1,330 posts
Posted 16 September 2010 - 08:37 PM
hello again people, noones looked at this but im gunna update it anyways
due to me being only 18, have points and a modified mini i cannot afford to insure it for a decent price,
i am therofore buying a small cheap to run car and spending the money (that im saving on petrol haha) on a welder
(ill be getting taught to weld by a family member)
shes only going to be off the road untill my 19th bithday (next march) or slighly longer
much of the work is welding, however i am including my wants list too :)
here`s the wants and jobs list:
welding-
2 new door skins (ones bad as shown on picture, the other is on its way there)
drivers front wing (fill and paint/replace wing job)
drivers doorstep (big hole in doorstep)
drivers floor plan (crack by subframe mount)
drive flitch panel (hole bottom of inner wing and doorstep)
passengers floorpan (hole bottom of inner wing)
inner sills on both side (origional outer sill was replaced before purchase of the car however some inner sill holes have been plated over so ill do the job properly this time)
quater light rear windows (corrosion at bottoms, passengers side is worse)
front bottom of both rear arches (corrosion in both places)
small part of boot floor (picture will explain easier)
rear valance closing panels (drivers side has hole and passengers side probably also but havent poked that much)
wants-
4x spotlights (wipac possibly)
standard 998 engine and ancillerys (if you know of one let me know)
panels for welding (will most likely go with non genuine accept possibly a genuine wing if its needed)
so there we are, i should be nice and busy for the next few months, i also mostly work 8 till 12 weekday shifts and full saturday and sundays so ill be working mainly in the afternoons, i also have access to a garage which is good
i hope people will enjoy my updates of my first project, ill get some pictures tomorow of the work ive got to undertake(and what im doing with the wing so far)
Lawrence
#13 lawrence
lawrence
  • 1,330 posts
Posted 09 October 2010 - 02:15 PM
so, ive not done alot of work and noones looked at this, but heres an update anyhow
ive stripped some of the car,
this picture is of what she looked like a few months ago (after she got hit)
she now looks like this
and this is my runabout
Edited by lawrence, 09 October 2010 - 02:23 PM.
#14 lawrence
lawrence
  • 1,330 posts
Posted 09 October 2010 - 02:49 PM
2nd update
current rust problem and a few question regarding tackling them
around the passengers side rear window
35640547616_65bb70fa8f_b.jpgDSC01828 by Lawrence Balls, on Flickr
can i get a panel for the back part? im not sure what its called but it look like its spot welder to the front and seam welded at the back. im not really sure how to tackle it
front of rear arch (passengers side)
35640547326_6882bf8bc8_b.jpgDSC01829 by Lawrence Balls, on Flickr
back of rear arch (pasengers side)
35549629611_498d107600_b.jpgDSC01835 by Lawrence Balls, on Flickr
inside door bin (passengers side)
35510912842_fd7e5967d1_b.jpgDSC01830 by Lawrence Balls, on Flickr
a panel to be replaced (passengers side)
35549632481_86e8f12bf1_b.jpgDSC01831 by Lawrence Balls, on Flickr
front wing possibly to be replaced (passengers side)
34870751443_12ce4b507e_b.jpgDSC01832 by Lawrence Balls, on Flickr
front view of engine with shiny pieces (i dont think the bay is that untidy)
34870751373_063c1a53a3_b.jpgDSC01833 by Lawrence Balls, on Flickr
painted wiper motor (first real work)
35549627081_af3575bc65_b.jpgDSC01840 by Lawrence Balls, on Flickr
front wing to be replaced due to accident damage at front and rust damage at scuttle (drivers side)
35510909962_6baff0f61d_b.jpgDSC01834 by Lawrence Balls, on Flickr
inside boot (both sides)
35510908742_bcdbbcfdce_b.jpgDSC01836 by Lawrence Balls, on Flickr
35549628201_8c22c3bbbf_b.jpgDSC01837 by Lawrence Balls, on Flickr
rear window (drivers side)
35510907302_3d7290871b_b.jpgDSC01838 by Lawrence Balls, on Flickr
feel free to make any comments and requests for pictures
ill make an update tonight or later,
hope you like
lawrence
Edited by lawrence, 03 July 2017 - 08:49 PM.
#15 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 15,910 posts
  • Name: Neil
Posted 09 October 2010 - 03:20 PM
With the amount of tin worm you have got in that rear quarter you need to seriously consider replacing it. Its pretty bad plus this will enable you to get internal access to the companion box area as well. You will probably need to replace the waist rail as well this is the section where the rear quarter attaches to the car behind the side window.
If you do go down this route i would highly recommend spending a little bit more cash on Heritage quarters, they fit very well as i have just fitted a pair to Project Erm and the waist rails. Have a look at the thread and you will see what i have done in those areas.
