Ken -The 1275 High Compression Engine Micra Mini (Running Project)
749 replies to this topic
#661 panky
panky
  • 1,776 posts
  • Local Club: Northwest Casual Classics
Posted 06 January 2018 - 10:46 PM
Excellent, sounds very nice too :mrcool:
#662 lawrence
lawrence
  • 1,330 posts
Posted 08 January 2018 - 05:23 PM
Thankyou, she is very vocal curently, silencing not what i hoped it to be!
Right guys, time for an update from Sunday.
So it was a day of ups and downs. Was getting pretty grumpy towards the end of the day as stuff went wrong
Start off good
So firstly I moved her to the garage so ive got some hard standing which is useful especially when its raining or windy as it’s a little more sheltered
25694369678_781e651696_c.jpg20180107_160449 by Lawrence Balls, on Flickr
Then started to go wrong. I was really struggling with the TPS. For some reason I just couldn’t get it to work. In the end I took the one off my motorbike. It should be the same although I know it’s the wrong direction
38856037854_12c6d3ed8d_c.jpg20180107_101224 by Lawrence Balls, on Flickr
That then allowed me to discover that the TPS on my ITBs is broken. I thought hey ill take it apart, maybe its repairable. Its not.
27788467129_46a3bc0125_c.jpg20180107_102805 by Lawrence Balls, on Flickr
somewhere along the way the ITBs have been broken and the TPS has taken a knock. The ceramic was broken meaning the traces were too. It was never going to work.
So then I spent a good 3 hours or so making this tps work (the one from the carbs)
39564650871_96d8ddfb3d_c.jpg20180107_110358 by Lawrence Balls, on Flickr
25694398678_b9e8717cfb_c.jpg20180107_112630 by Lawrence Balls, on Flickr
24697116227_6123a98a7e_c.jpg20180107_115850 by Lawrence Balls, on Flickr
25694378338_ffbfe6719b_c.jpg20180107_115854 by Lawrence Balls, on Flickr
Well what a waste of time that was. I can’t create a bracket that’s strong enough and would need to make an adaptor inside it also and then it would look rubbish in the middle of the engine bay. Stuff you TPS- plus I was very cold by then and easily annoyed.
So what have I done.>
Bought another ITB setup that’s fully complete for £40 as to buy a single TPS is about the same. And also bought a wiring plug for it too as opposed to soldering the connections onto it as before.
 And what else is bad
>never did the air test with the wideband or plugged it in and ive been running the engine up to temp and everything, may have buggered the o2 sensor. Will find out on my next day off. – could cost me
So after that I did stuff I knew would work
Bit of soldering and some glueing 24697042967_e4639a1fd9_c.jpg20180107_165921 by Lawrence Balls, on Flickr
Ta da
39564557261_f4bfa3bb43_c.jpg20180107_174507 by Lawrence Balls, on Flickr
headlights bright too
25694336938_9345d7f7ca_c.jpg20180107_175016 by Lawrence Balls, on Flickr
but as you can see. Numberplate led has gone. Urh
So to summarise yesterday
>TPS broken - £45 down for a new one and connector
            >wasted about 3 hrs faffing
>Numberplate light – new one needed
>O2 sensor may be broken - ? another £50, such fun
But positives
>New ITBs will supply me with loads of spares!
>new numberplate light comes in pairs. Hey another spare!
>brakes work on car. Spongy but work!
>drivers seat fitted – can make brum brum noises and move car back and forth
>purchased tuner studios autotune software so should make my tune better!
That’s all folks
Lawrence
#663 lawrence
lawrence
  • 1,330 posts
Posted 10 January 2018 - 11:06 PM
Right people, a little update from a few evenings/afternoons.
ITBs arrived on Tuesday, checked them over and they look ok, my assistant checked also, she said they were mrow mrowok so that’s good
38910623264_b54e8113e7_c.jpg20180109_222832 by Lawrence Balls, on Flickr
stripped to components and stored spares for the future.
Then my connector arrived so tested my new crimping dies, well awesome and no solder needed.
38910623134_eb1f1f0b84_c.jpg20180110_164254 by Lawrence Balls, on Flickr
Nice and waterproofed
39618657021_e7d9af4ba0_c.jpg20180110_165326 by Lawrence Balls, on Flickr
So I also needed to refit the waxstat for the ITBs, I took it off because I thought I would get a good idle with megasquirt but I cant. Obviously. I'm an idiot. So need to plumb the waxstat in.
38910582334_ce23390798_c.jpg20180110_180404 by Lawrence Balls, on Flickr
but there's no plumbing L or is there???? J
24750524697_a10f939273_c.jpg20180110_180348 by Lawrence Balls, on Flickr
There's normally an output here for the throttle warming circuit. Its blanked with a sensor now. I have a spare one to fit. So that’s my output from the cylinder head.
Inlet is blocked with weld isn’t it (by me of course)
39618649571_cdfaf80348_c.jpg20180110_180321 by Lawrence Balls, on Flickr
But wait. Before I have to faff about with drills and flushing coolant etc etc there's another way
38910589764_3df9894f4d_c.jpg20180110_190213 by Lawrence Balls, on Flickr
that’s the inlet on the radiator, now it is currently blocked off with a threaded bolt and some sealant.
So, the plan is to fit an output from the cylinder head that isn’t welded up (found it already) and plumb in the inlet to the radiator. It would mean that hot coolant would be flowing from the engine – through the waxstat – to the rad to be then cooled opposed to hot coolent bypassing the rad, which seems to make more sense!
Only issues I can see may be bleeding the system as the top will then be the wax stat. Not the end of the world for a better idle.
I've also ordered some more hose and adaptors as I don’t have the parts and although I can make some brass 8mm to 5mm adaptors on a brass bar mounted in a drill it's not worth my time to at the moment. Maybe another time
That’s all for now, I'm doing a bit of wiring tomorrow evening after work but I won't update as its only bits and pieces.
Lawrence
#664 l_jonez
l_jonez
  • 1,453 posts
Posted 12 January 2018 - 12:07 AM
It's been a while since I caught up with you build, congrats on the start up. You will be able to get a good idle with megasquirt, it's just a bit of a pain to get the cold start dialled in, I do believe tunner studio now has a cold start auto tune? It's been a few years since I played with my ITB's.
Oh and the cat scan is a reassurance
#665 thelegg
thelegg
  • 601 posts
Posted 12 January 2018 - 01:20 PM
Surprised your assistant didn't say the ITB's looked purrfect ;) those crimps look good to
#666 lawrence
lawrence
  • 1,330 posts
Posted 13 January 2018 - 07:25 PM
Cheers for the comments guys
I do agree with you there Lawson about the cold start. I think im getting there gradually with it although it is frustrating at times when the engine catches but then dies repeatedly.
There is a warmup auto tune but cold start is down to me to get right
At the moment starting wise the engine catches, if I put a puff of easy start down the ITBs the engine jumps to life so I think it’s a little lean still cranking. Ill get there.
So ive had a day off today and its been a mini day.
In no particular order
>New washer pump fitted, can now use wiper washer for MOT
>Near rear numberplate lights fitted – One broke, have mailed seller for another one
39640273022_d777eb34c2_c.jpg20180113_110729 by Lawrence Balls, on Flickr
>Misc wiring inside sorted.
>New phone mount made and carbon panel trimmed. Buttons will go on the bottom left and right. Left will be horn, right will be sport button (to elaborate on later)
24802216327_d697e29e31_c.jpgIMG-20180113-WA0003 by Lawrence Balls, on Flickr
>TPS wiring checked and uploaded the values to the squirt – will complete soldering connections tomorrow
Main update,
Autotune fully used.
Ive started the engine up with autotune – its leaned off loads of boxes by about 30% - I re formatted the O2 sensor just to be safe too and its made it run loads better. Only been able to rev it up to 2.5k aprox due to time of day (1900pm) and it needs so runs up and down the road.
Nice and responsive when you blip the throttle but it still wants to die (revs drop to 600) when you come off it so it needs to tune those areas more
Best money ive spent recently!
Ill put a video up soon also
As normal something bad has to happen
>Somehow the dihastu charade alternator isn’t charging the engine, im not sure if something has gone in the wiring or something else but I may need a new alternator. Not the end of the world.
All for now. More tomorrow night. Got a whole day with her tomorrow not a half day like today! Early start for me!
Lawrence
#667 lawrence
lawrence
  • 1,330 posts
Posted 15 January 2018 - 10:37 PM
So little update from the last few days, there will be more coming up in the next few days or so. Im spending time with the GF tomorrow but Wednesday is a garage day again so means more road testing hopefully.
So I have finished off the interior wiring now bar a few things that have yet to arrive. For the time being the wiring is hidden behind the dash so that car looks complete at least.
In all her glory
39712761071_36ae8bd9d2_z.jpgIMG-20180114-WA0001 by Lawrence Balls, on Flickr
Looking rough as a badger’s arse poor thing. But complete enough to drive
More on that shortly
Onto the steering wheel mods
38982703564_2e6d933566_z.jpg20180114_182207 by Lawrence Balls, on Flickr
And though the cunning use of heatshrink, a project box, some tubing and grommets ive made something half decent looking
24822984847_d4e1a27b21_z.jpg20180114_192623 by Lawrence Balls, on Flickr
tidy from the front
24822981337_e3da0be97a_z.jpg20180114_192617 by Lawrence Balls, on Flickr
So to thanks for this great idea is Barry from the Nissan mini owners club on Facebook. There are RF transmitters hidden in the project box linked to each switch. Now with a bit of nifty wiring consisting of a step-up circuit, another RF receiver, a rechargeable 9v lithium battery with inbuilt circuit and perhaps a bigger project box I should be able to have those switches lighting up when I turn the side lights on. Wirelessly. With a 200m range. That will be awesome J. I am a sad sad man!
And lastly I turned her round
25819354158_96119d53d5_z.jpg20180114_132952 by Lawrence Balls, on Flickr
because I had taken her for a spin
39692868951_eb2809d6e7_z.jpg20180114_133049_1 by Lawrence Balls, on Flickr
Negatives
>Suspension is low, front tyres are touching the arches when I turn the wheel and im going to have to go down my drive diagonally from now on
>No power on acceleration – need to drive and tune her.
Positives
>It moves
            >Clutch – works
            >Exhaust – exhausting (think its leaking a little)
            >Brakes – brakes work (well mini didn’t roll down the drive into the neighbours rockery, bit spongy but meh they had a leak didn’t they. Ill bleed them again)
            >Nothing fell off – happy with that point
            >Suspension is a little bouncy but less crashy compared when she was last on the road
that’s all for now. More soon. Oh and ive bought a digi dash – should come soon. Its not the new digi dash 2 is the original but has the same functions just is more rectangular.
Lawrence
#668 lawrence
lawrence
  • 1,330 posts
Posted 20 January 2018 - 07:02 PM
Right people,
New update.
So I said before the exhaust is leaking a little, well I drove her again the other day, its leaking alot!
39754491872_77fabaac17_z.jpg20180119_110734 by Lawrence Balls, on Flickr
nice bit of smoke there
hmm, cheeky crack
39786162631_078ae05705_z.jpg20180119_110829 by Lawrence Balls, on Flickr
cleaned and rewelded
28007725179_dc14c8a082_z.jpg20180119_115459 by Lawrence Balls, on Flickr
I can only assume that when I did it up they broke, don’t remember it but meh
Also im a little worried about the exhaust seal before the lambda so cleared out the sealent and popped a few tacks on to support the join.
39075903954_2f9098e293_z.jpg20180119_120728 by Lawrence Balls, on Flickr
Sealed up after
28007736719_b57afdd4f9_z.jpg20180119_121437 by Lawrence Balls, on Flickr
Also got my Bluetooth system to talk to my mobile phone which is pretty cool
38882382305_6f5e2fb91f_z.jpgUntitled by Lawrence Balls, on Flickr
started on my new dash
24930554657_da613757ae_z.jpg20180120_131232 by Lawrence Balls, on Flickr
28022588419_565791005f_z.jpg20180120_133229 by Lawrence Balls, on Flickr
39091034774_32f81d3195_z.jpg20180120_143428 by Lawrence Balls, on Flickr
39801009811_1ffa687f8a_z.jpg20180120_145629 by Lawrence Balls, on Flickr
39769345082_2d225599a8_z.jpg20180120_150954 by Lawrence Balls, on Flickr
39769324062_6948d4b7c4_z.jpg20180120_154417 by Lawrence Balls, on Flickr
25928437388_f7a191a3c3_z.jpg20180120_161749 by Lawrence Balls, on Flickr
38901923765_5131f4e919_z.jpg20180120_172450 by Lawrence Balls, on Flickr
fitted
28022513749_60ed0e6aff_z.jpg20180120_175053 by Lawrence Balls, on Flickr
wiring sorted now too. Just the digidash bits left
24930562987_f43cddcf95_z.jpg20180120_122147 by Lawrence Balls, on Flickr
new roof light. its remote control!
24930769907_2c3b5f6a46_z.jpgIMG-20180120-WA0013 by Lawrence Balls, on Flickr
Removable wheel
25928682148_f9a4aff56e_z.jpgIMG-20180120-WA0000 by Lawrence Balls, on Flickr
That’s all for now. More road tuning.
To do
>road tunes
>brake bleed
>suspension putting up
Lawrence
#669 miniaddict92
miniaddict92
  • 362 posts
Posted 23 January 2018 - 12:13 PM
love the update dash turned out really nice
#670 lawrence
lawrence
  • 1,330 posts
Posted 23 January 2018 - 09:19 PM
Thanks, it looks really good in the daylight too!
So since my last update I have rebled the brakes and this morning I have put the suspension up, it drives a bit better now too.
39152030764_0dd9779eb0_z.jpg20180123_114855 by Lawrence Balls, on Flickr
Rewelding the exhaust has also made her run loads better, she idles better and pulls more consistently, only been up to gear three but then again I'm only driving her around a small area.
To do list
>Few bits of wiring, indicators are a bit fast still, need to fit a resistor
>Check the alternator, need to get it working
Hopefully booking the mot in the next few weeks
Lawrence
#671 lawrence
lawrence
  • 1,330 posts
Posted 25 January 2018 - 11:19 PM
So one bit from today but it took me a while.
I forgot to add in the last post I was getting a clunking sound when driving on harsh acceleration and a lot of vibration on the steering that felt like it was coming from the NS driveshaft area. But only on if I put my foot flat on the floor
This morning with assistance from my dad who was rocking the engine violently although it was under harsh acceleration I checked my clearances, at max force from him, the driveshaft gaiter protector that I made was catching ever so slightly on the subframe.
I decided to modify the rear engine steady to something more rigid.
Micra mount as was next to spare landy mount
25027797797_f1cec36495_z.jpg20180125_123545 by Lawrence Balls, on Flickr
mount hollowed out
39000349345_4797512cd7_z.jpg20180125_124557 by Lawrence Balls, on Flickr
landy mount trimmed just enough, had to use a grinder for the steel and a jigsaw for the rubber. Then finally I could press it in gradually using the vice
25027787817_f471484b85_z.jpg20180125_133108 by Lawrence Balls, on Flickr
Then I welded some tangs on the side and waterproofed it with some sealant after a bit of paint on the bare steel
25027775677_17733421ac_z.jpg20180125_142701 by Lawrence Balls, on Flickr
So the mount is back in the car and everything is back together, did the rock test and the engine is so much more solid, clearance upped a little giving 8mm so I'm happy. I also got my dad to do some throttle tests on the drive while I listened out, no noise. hopefully it's fixed. The next road test will confirm or deny
Then dad stalled her and the battery didn't have enough charge to start the engine
to do
>get that bloody alternator working!
#672 McMini 22
McMini 22
  • 289 posts
Posted 27 January 2018 - 04:20 PM
I'd keep an eye on it. These landy mounts are supposed to work in compression.
Using it the way you have you are relying on the bond between the rubber and the plate with the the threaded stud.
#673 thelegg
thelegg
  • 601 posts
Posted 27 January 2018 - 08:03 PM
I had the same problem using the nissan mount at the back in the end so swapped it out for a polyurethane bush from a honda s2000 it firmed everything up lovely :)
#674 lawrence
lawrence
  • 1,330 posts
Posted 27 January 2018 - 11:58 PM
Cheers for the comments guys, I'm aware the mounts are for compression but basically, for mine at the back of the engine the mount is only acting as a steady. If I do have any issues with it all honestly all probably buy an allspeed frame as that comes with the mounts and won't have the driveshaft clearance issues I've had in the past!
So today ive only done a little. Im now saying for a house so getting rid off my excess mini parts so that took a while. Sorted my coil bracket out tho
39902569282_ecc2bcff5d_z.jpg20180127_115250 by Lawrence Balls, on Flickr
39902559692_c2b62781f1_z.jpg20180127_123018 by Lawrence Balls, on Flickr
39224390114_5bab31d288_z.jpg20180127_124212 by Lawrence Balls, on Flickr
39224409304_0cc6071fe2_z.jpg20180127_133422 by Lawrence Balls, on Flickr
Its now fitted but i didnt get a pic,
then i extended the wiring to the coil and took her for another spin round the block to test the new engine mount
28155036659_a725d55ae7_z.jpg20180127_145151 by Lawrence Balls, on Flickr
And that photo was taken when she had her first breakdown!
Megasquirt main relay went open circuit between the low side of the relay and popped a run of fuses, horrible smell of burning from one little relay but took me 20mins to identify the problem. Didn't help I had put a 10amp fuse at the start of the circuit and a 15 between the 10 and the relay meaning the 10amp one behind the bloody dash had to be changed!
fixed now and some new relays ordered.
Job added to list
>load test all circuits and buy applicable fuses. May buy some self-resetting ones for the fuse box behind the dash.
Lawrence
#675 lawrence
lawrence
  • 1,330 posts
Posted 06 February 2018 - 11:47 PM
Right time for a little update,
Due to wanting to buy a house in the near future I have limited myself to what I can spend on mini by what I can sell from my accumulated parts. So I have sold loads of my random bits off and raised some funds. Sold about £150 I recon, maybe a little more.
And what I have bought
>Front splitter (with permission from Chris1992 to copy his style partly)
>Front tow eye (girlfriends recommendation for styling)
>Halfords vortex sock set
>Alternator regulator
Wiring is now mostly finished. I need to make a bracket for my speedo for the digidash and also link the digidash to megasquirt for the revs so that is my plan for tomorrow
New numberplate lights finally fitted
26250591858_b5035abd44_c.jpg20180206_170442 by Lawrence Balls, on Flickr
