Clutch problems?
Posted 04 October 2005 - 03:42 PM
This might be the cause why the mini has no power and can't get over small lips.
Also theres oil coming out somewhere, I think it's the rubber gaitor connecting the metal rod (that goes to the gear stick) to the gearbox.
Can anybody shed any light on the situation? If I need to replace the clutch is it an easy job?
Posted 04 October 2005 - 03:54 PM
The differential transmits power from the gearbox to the wheels, but it does it in a fashion ( without getting too technical ) which allows the wheels to turn at different speeds, so you can go round corners. An effect of this is the power goes to the wheel which has least resistance to turning.
And the leaky oil thing is typical of minis, you can get a kit which attempts to fix it, works sometimes, or you can just get another seal and push that in...
PS, the teeth on the flywheel are for the starter motor to engage on, not drive the car.
Posted 04 October 2005 - 04:14 PM
Both the wheels were up in the air and they were both straight I just thought it was weird that it wasn't spining at all, even if the other wheel was spinning where would the noise of been coming from it didn't sound healthy but perhaps it was normal.
Also when the mini is stationary and theres a slight lip the clutch can be fully up and it won't moved even if I'm revving it, shouldn't it stall?
Posted 04 October 2005 - 05:43 PM
Posted 04 October 2005 - 06:30 PM
Posted 04 October 2005 - 06:58 PM
start the engine with the handbrake on. leave it on and find your biting point, the car should dip at the back and try to learch forward. if not you've a dud clutch. simple but effective :cheese:So it's most likely the clutch has gone :sad: damn thats more money down the drain, would have been cheaper if I'd bought a working mini.
Posted 05 October 2005 - 04:40 PM
Posted 05 October 2005 - 05:09 PM
this is true i remember my drive shaft popping out the engine on mine, could be the inner cv joint, have a good feel of the rubber gator, if you can feel lots of balls about the size of a marble then the joint has come apart.it could be the inner pot joint has come adrift alightly. check it, pand make sure they are both pushed in. it has happened to me when my mini was up in the air! to much suspension travel.
Posted 07 October 2005 - 01:37 PM
That seems more likely, I new the clutch was biting but I couldn't diagnose the problem. Too bad it's wet outside otherwise I'd go and have a proper good look now.it could be the inner pot joint has come adrift alightly. check it, pand make sure they are both pushed in. it has happened to me when my mini was up in the air! to much suspension travel.
Cheers for the help
Posted 07 October 2005 - 01:50 PM
Posted 09 October 2005 - 12:58 PM
