metro caliper seals
pistin broke
, Oct 04 2005 09:15 PM
14 replies to this topic
Posted 04 October 2005 - 09:15 PM
:nugget: can any one tell me were i can get the rubber seal from that goes between the calipers on 4 pot metro brakes. not the piston seals . the ones in the caliper its self
the rubber is still soft but i would like to replace them. PS i did not split them they were like that when i brought them did not know you should not seperate them
any help would be great .CHEERS
Posted 04 October 2005 - 09:42 PM
In the past you could never get them or the new bolts needed. or the torque wrench settings for the bolts
Siggy
Siggy
Posted 05 October 2005 - 11:24 AM
As Siggy says above... this is why ALL the manuals say do not split the two halves of the caliper...
Your only option is to use the seal you have, and the torque level is around 70lbft, and use locknut on the bolts.
The reason I say 70, is that's how much torque it took to remove a bolt from a severly corroded pair I had.
Posted 05 October 2005 - 08:19 PM
Get another caliper,
How much is your or anyones life worth
Siggy
Siggy
Posted 05 October 2005 - 08:33 PM
thanks. I rang minispares this morning and asked if they did the rubber seal
and they said no .I then rang AP LOCKHEED who told me they carnt sell to the public but they sell to minispares so i rang minispares back spoke to someone differant who said yes we do sell the seal and they cost 61p each.still trying to find the bolts but some one must do them what about an engineers shop??????.any ideas.thanks guessworks 70 pounds sounds better minisport said 25 and use nutlock but that was only a guess.
Posted 05 October 2005 - 08:45 PM
70 was the torque needed to remove a set from a corroded caliper, not to tighten new bolts in a new caliper.
Siggy
Siggy
Posted 05 October 2005 - 08:58 PM
true siggy very true.but whats the big deal about these bolts why carnt you buy them i know they stretch when you undo them but you must be able to buy them.
Posted 05 October 2005 - 09:20 PM
They don't want people messing about with calipers.
Siggy
Siggy
Posted 05 October 2005 - 10:06 PM
i'm looking to get re build kits for my 4 pots as the seals were hard and the pistons were starting to sieze in the caliperwent to mosses but they said they couldnt get the kits do minispares do them?
Posted 05 October 2005 - 10:52 PM
Mayube slightly different because mine are alloy, but I've just had to take the spacer out of my KAD 4 pots and they didn't have a problem with me doing that, gave me new O-rings to use, and sent me shorter bolts, and told me to torque them to 25 (can't remember whether they stated Nm or lb/ft though).
Posted 05 October 2005 - 11:08 PM
thats what i mean why sell the caliper seals but not the bolts
AP said that minispares recon their own.it dont make sence
Posted 06 October 2005 - 05:11 PM
I rang AP again today and left a message with a bloke called ken ewers
i asked him the torque settings for the caliper bolts he got back to me and said it is
35 to 39 newton meters if that helps any one. just have to find the bolts now or use the old ones with some nut lock. THE TRUTH IS OUT THERE :fear:
Posted 06 October 2005 - 05:27 PM
If the bolts are torque yeald (stretch) bolts
DO NOT REUSE THEM
Siggy
DO NOT REUSE THEM
Siggy
Posted 06 October 2005 - 05:56 PM
do you think an enghineers will get them
Posted 07 October 2005 - 07:20 AM
No
They would not know the tech spec of the bolts.
Is it worth the effort!!!
Buy a secondhand caliper
Siggy
Siggy
