induction kits
Posted 05 October 2005 - 06:48 PM
just thinking what i could do to get that little bit more from the engine without it costin a arm and a leg... i've seen induction kits on modren cars and have seen it done on minis.
see pick as i have just fashioned this from the pipie that sits under the left wing. i'll just rested it on at the moment so you get the jist of what i mean.
so basically does this work
Posted 05 October 2005 - 07:02 PM
Posted 05 October 2005 - 07:08 PM
Posted 05 October 2005 - 07:32 PM
Right then, i've seen lots of Minis since i've been messing around with them again with flexable large bore ducting running from the front of the car near the grille to the area where the carb inlet filter sits. A mate of mine with a MPI has got two!
I thought i'd perform a little experement last night and rigged up a temperature probe next to the air filter on the left hand carb on The Shed. The probe was about an inch from the K+N round filter itself. The ambient last night was about 18-19 Degrees when i left here last night. But before i left i got into the car and started it up , just to check that it would start, i ran it for about 2 minutes and then turned it off. When i eventually set off the temperatre under the bonnet had climbed to 34 degrees, due to me starting and stopping the engine. After aproximately 30 metres the temperature under the bonnet had dropped to 18 degrees. Once the engine was thoroughly warmed up at Sandford Hall village i dropped my speed down to 30 for the trip through the village and past the camera. When i entered the village after cruising at about 60-70 mph the temperature was 18 degrees, driving along at 30 the temp was STILL 18 degrees. I tried this several more times and came to the conclusion that as long as you are doing more than about 20 mph the air around the carbs was at the same temp as the air outside.
Conclusion (this is for my car, yours may be different, i doubt it, but it could be different).
From what i have seen ducting air from the front to the back of the engine bay does no more to affect under bonnet temperature above 20mph than having no ducting at all. Below this speed it may have some effect, but then again as soon as you go more than 30mph the temp has dropped to ambient anyway.
I was going to duct some "cooler" air back to my carbs but i dont think i'l bother now, it all seem a bit of a waste of time.
Posted 05 October 2005 - 07:46 PM
Posted 05 October 2005 - 08:17 PM
it was just a thought!!!
but i got an idea for a new topic??
Posted 08 October 2005 - 03:34 PM
Can't remember where I found this pic :wink:
Posted 08 October 2005 - 03:52 PM
Posted 08 October 2005 - 04:49 PM
it works in the way that it gives vibrations to the air before it enters the carb
but how long it should be depends on the frequence that your engine has on max. rpm
so you need quite fine tuning when installing something like this
you need a pipe of 80-90cm when you have 300° cam eg.
but if you tune it fine enough, it will increase your torque so basically it works but its not easy to get it working
Posted 08 October 2005 - 07:01 PM
Posted 09 October 2005 - 10:33 AM
Posted 09 October 2005 - 10:42 AM
and as i had this laying around in the garage i would ask if it was worth it.
