bit's and mod's
Posted 05 October 2005 - 08:24 PM
I was wondering what mod's or adjustment people have done to thier mini's, that have cost pennies or used or fabricated items that they have already owned to make thier mod's. and if they worked and if they are still workin.
Plus you can boast of how clever you are!!! pic welcome
cheers-pepe
Posted 06 October 2005 - 12:19 PM
splitfire plugs
alloy inlet manifold
1:5 rockers
RC40 exhaust
good air filter
hif44 carb
I found that this made a massive difference, also try to never use supermarket petrol as u will never release the power from your mods because its *******, always try and use optimax or super unleaded.
Also the little things make a big difference ie. having the rite fuel mixture and geting the timing done on the contact points in the distributor.
Got a HIF44 carb if u want to buy it?
Posted 06 October 2005 - 12:45 PM
£1 of pipe from B&Q later and car drives great
Posted 06 October 2005 - 02:49 PM
Posted 06 October 2005 - 03:15 PM
Posted 06 October 2005 - 05:24 PM
Posted 06 October 2005 - 06:18 PM
supermarket petrol is ******* i agree, this is due to the fact that they purchase their fuel at auctions to keep prices down.They buy any old cr*p thats going where as shell, bp etc have their own refineries and make their own petrol. even standard unleaded from shell is better than the supermarket equivellantI put some 10mm k+n leads
splitfire plugs
1:5 rockers
RC40 exhaust
good air filter
hif44 carb
Posted 06 October 2005 - 06:31 PM
Posted 06 October 2005 - 06:47 PM
need to use it a few times to clear the other stuff out. is it an injection or carb? think it takes a while for an ecu to accept the change in an injection. or i could chattin sh*t. i was told this by someone at london brighton two years ago.I always use supermarket petrol... i put the shell suff in one day and my car ran like a bag o bolts for that tank.
Posted 06 October 2005 - 06:54 PM
Posted 06 October 2005 - 06:56 PM
the complete dash is made of bits of alloy out of the scrap bin in work, as is the engine bay bulkhead (rivetted together, and held in with titanium screws!)
most of the nuts and bolts are freebies from work.
the door cards are made from sheet fibreglass that normally lines the cargobays of airliners (1/16" thick, tough as anything and flame retardent!)
one of my finest freebies is the switch box in my mates race car.....the box itself is from an aircraft, is has aircraft circuit breakers for fuses, aircraft sitches , some with aircraft red flip covers on, the starter button cost £3.......and if you had to buy the bits to make the box you wouldn't get much change out of £500..!!
