Reconditioning Subframes
Posted 06 October 2005 - 11:29 AM
Just got back on working on my mini, i've removed my subframes, , the rear one was all rusted, so i bought myself a new genuine one.
Im getting all arms and the front sub shotblasted, and givin a special metal coat (its called "metallisering" on danish, cant seam to fin a english word for it).
I want the ultimative rustproof subframes, What to do next..? Powder coating? Or just some special paint? what are the cons and pros.
And what should I do with the new rear subframe.. I've heard that its paint aint that good...
Please help a newb :tongue:
Posted 06 October 2005 - 11:51 AM
Posted 06 October 2005 - 12:10 PM
Powder paint is great, but it chips and peels easily from flat surfaces (particularly ones subject to impact... like subframes). POR paint is a very tough, impact resistant paint. It's weakness is that there is a lot of preparation involved and the cured product discolors when exposed to sunlight. It can be topcoated with more traditional paints (like the epoxy) to achieve a long-lasting uniform color.
Posted 06 October 2005 - 12:48 PM
Posted 06 October 2005 - 10:04 PM
If available to you in Denmark, use POR-15 (sold by Frost in the U.K.) with a top coat of black epoxy paint.
No doubt.. I can get it.. If I understood it correctly, one bottomlayer of POR15 metal ready, and then a coat of POR15 Rust prevention, and a layer of chassis paint..?
Will that last long?
Posted 07 October 2005 - 06:06 PM
Posted 07 October 2005 - 08:48 PM
You'll get an application data sheet when you buy POR products. Succinctly, strip the part to remove all old paint and coatings. Wash the part using POR's "Marine Clean" degreaser. Remove the surface rust using whatever method you prefer and wash/rinse again. Treat the surface with POR's "Metal Ready" which is a phosphoric acid treatment. Keep the Metal Ready on the bare metal for a LONG time (making sure to keep it wet). You'll build up a grey coating of zinc phosphate. After you've got a good phosphate coating and the surface is completely dry, you apply two coats of POR paint allowing sufficient time between coats (see their instructions). After the second coat has almost dried but is still slightly tacky you apply a fog coat of primer. (Do not waste your time or money on POR's "Tie Coat" primer). Let the POR and your fog coat of primer dry for a day then come back and spray a nice coating of chassis paint. I use Eastwood's "Chassis Black".
POR can be sprayed but I suggest you use a VERY cheap spray gun. POR will cure on your skin and can't be removed with solvent. You have to wait a few days for it to wear off your skin. Be sure to wear gloves and clothes you don't care about.
Visit their web site for more info on the products:
www.por15.com
You may also want to look at the product description/application notes at:
http://www.por15.com...es/por15sum.pdf
Posted 08 October 2005 - 10:12 AM
Posted 08 October 2005 - 11:12 AM
The purpose of using a fog coat instead of laying down a regular continuous film over the surface is to allow solvents to evaporate. This is VERY important with POR. I like the stuff but it's not as easy to apply as they lead you to believe. You MUST allow sufficient time between coats, and you must apply no more than a fog coat of primer, OR the paint applied on top will trap solvents in the bottom coats. The solvents have to get out and they make it to the surface as little pin-hole bubbles that ruin the protective film. Follow the POR instructions carefully regarding when to apply second coats. The fog coat of primer provides an anchor for the "real" coat of primer applied later yet it allows the solvents to escape.
Any primer compatible with your top coat paint will work. The Chassis Black paint I use is an epoxy with satin finish. It is compatible with spray-can type primers. The epoxy top coat protects the POR from UV light which will discolor POR.
I've noticed recently that POR has been used on some of the Mini World projects. I'll be happy to share my experiences with it. So far, three years on, I'm still happy with my results.
Posted 08 October 2005 - 11:34 AM
Posted 08 October 2005 - 08:21 PM
Excellent! What do you mean by the real coat of primer applied later? Surely it would be metal ready, por15, fog primer, chassis black? Isn't that enough!!!??? :grin:The fog coat of primer provides an anchor for the "real" coat of primer applied later yet it allows the solvents to escape.
Posted 09 October 2005 - 02:00 AM
Posted 09 October 2005 - 03:45 PM
