how would i tell if i had an unleaded head, if i havent, would this be the reason my engine is smoking??
unleaded head
myblueberry
, Oct 07 2005 08:04 PM
5 replies to this topic
Posted 07 October 2005 - 08:04 PM
Posted 07 October 2005 - 08:26 PM
Well i can help you there, if you had a leaded head you would not be able to lift your head from the pillow!! and when your sitting upright your head will be very hard to hold upright, just like a new born babies...how would i tell if i had an unleaded head...
Hope that helps!! :cheese:
Posted 07 October 2005 - 09:37 PM
LOL@barnett
the only way is to remove the head and the valves and look for the inserts
Posted 08 October 2005 - 04:56 PM
try leaded fuel and look if its still smoking
no warranty for your engine
Posted 08 October 2005 - 11:57 PM
Check for exhaust valve seat inserts. here's an insert, prior to final cut. the lip being talked about is about 1/4 down from the surface. If it's smooth all the way around, from surface down into the port, then it's not inserted/unleaded. If you feel a hard, 90 degree lip and opens up a bit more after that, then it's got inserts.
:twisted:
:twisted:
