Hi all
998 A+ engine.
Still having severe overheating problems.
All water stuff- stat, pump etc replaced. New rad.
Head gasket done and compression check is in the green on my gunsons gauge.
Timing is a bit out - slighly below the jaggedy marks on the timing marks.
On tickover on teh drive , goes to N fairly quickly and then sits there OK, but gets very hot quickly when under way. Gets to the top of the temp gauge in about 3 miles.
Is my engine knackered or have I forgotten something?
ANY ideas welcome!!
thanks all
cheers
colin
Kerr- boom ??
campfreddy2
, Oct 08 2005 12:54 PM
6 replies to this topic
Posted 08 October 2005 - 12:54 PM
Posted 08 October 2005 - 01:11 PM
checked hoses are clear?
what degree thermostat are u using?
Posted 08 October 2005 - 02:03 PM
set the timing properly and check the carb settings, this should improve things if you have checked everything else!
Posted 08 October 2005 - 02:23 PM
Make sure your fan is sucking and not blowing... to be honest, though, sounds like your guage is dodgey / wrong one.
Posted 08 October 2005 - 05:18 PM
Dodgy temp sender?
Posted 08 October 2005 - 10:42 PM
After guage has hit high feel around under bonnet. Do hoses, rad top feel extreamly hot. VERY VERY carefully start to release rad cap, if no hissing and bubbling carry on ONLY TO FIRST CATCH.
I had same problem but found that i could remove the cap completly after a 15 min run with guage uo in red. Dipped water with a meat thermometer and only read 77 deg c. Change sender unit and all hunky dory. Never goes above 1/3 now, even in traffic and/or a good ragging.
